Driver side rubber lining loose - how to fix
Hi guys,
I do not know what the piece is called so bear with my description of 'driver side rubber lining'
. Anyone know what that piece is called?
If you look at the pic, it is loose. Everytime I push it back in, it will come off. It doesn't have that 'snap/close' feedback. Anyone know a way to fix this?
![](http://pic100.picturetrail.com/VOL783/3746656/24077246/403752529.jpg)
Thanks.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Thanks.
rubber is stretchable, which is why its often times not installed perfectly. what you should do is pull more of it up, stretch the part that goes straight, and then that way you have slack on the corners, then it should stay in effortlessly. this is done so you're not trying to stretch it over the corners. this will work if you do it right, lemme know if you need any more clarification
rockyboy
12-06-2022 02:29 PM
sockr1
10-01-2015 01:31 AM
