Door speaker
Old Apr 9, 2012 | 12:53 AM
wdelacruz's Avatar
Door speaker
i need to remove the speaker and i dont knwo how can some one help me please
Old Apr 9, 2012 | 09:27 AM
SharksBreath's Avatar
BANNED
which ones? front, rear?
for the fronts you have to remove a little plastic cover behind your door handle (little flathead should take it out) and there is a phillips head screw behind that. remove that screw. there is also a phillips head screw under the armrest section. you'll feel the hole underneath the armrest right above the cubby pocket section. stick the screwdriver up there and take it out.
those are all the screws. pull the door panel towards you, that should break it lose...then lift up and remove all the harnesses that are plugged in once you can get to them.
speaker is easily taken out with phillips head screwdriver...maybe 4 screws holding it in place.
replace everything in the reverse order.
if you need to replace your OEM front speakers, let me know...i have mine for sale. send me a PM if interested.
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
polish_pat
Sep 25, 2015 12:24 PM
