DIY A-105: Power Steering Whine fix
#242
bump
#243
O-ring Power Steering Inlet Fixed 2005 TL whining sound
Just want to the thank this forum for posting this information!
I went to my Acura dealer last week after temperature went down to single digits and the noise from P/S started in my car. The service rep I talked to said they were replacing a lot of P/S pumps but he wasn't aware of this O-Ring issue. He looked it up for me however, and sure enough found Service Bulletin 07-060 from April 3, 2009. They would have fixed it for $75 but I changed it myself.
This has completely eliminated the cold start noise. There was a little residual noise at first when actually turning the wheels, which has since went away, that was due I believe to air bubble still in system since I didn't drain the fluid.
I would note that on my 2005 TL there is very little space around the bolt, and 10mm wrench with built in ratchet on one side was actually too wide to get to the bolt. Only the most basic wrench will do.
Thanks again for saving me the price of a new pump (at least for now...)!
#244
As everyone else has said these forums are great for finding fixes that stealerships will charge you ridiculously for! Mine started whining yesterday after sitting outside in 3 degree weather all day. It was whining again today, and noticed that the whine gets louder when I turn the wheel at a dead stop, but goes away after my 45 minute drive home from work. Do you guys think it's likely to be the pump or just the o-ring? Also, I'm at about 99,200 miles as of this afternoon.
#245
^ o ring
#246
I hear your question given mileage on the car. But nothing much to lose if you change the O-Ring and end up needing a pump later. if there is a real problem with the pump however, it doesn't get better after driving it more. Another check you can do is open the P/S fluid reservoir and shine a flashlight into the fluid. If air is flowing into the system, making the whine, then you will see lots of fine little bubbles in the fluid. If fluid is really low, then you may have a leak somewhere which is a different problem, but this wouldn't get better by driving it more or having the car warm up.
#247
Fluid level in the reservoir will be high when the car is turned off because the o-ring allows air into the suction line which causes all the fluid in the line to back up into the reservoir. When you start the car, the excess fluid is sucked out of the reservoir and back into the system, and the air in the suction line ends up as foam in the fluid. This can make it difficult to read exactly where the fluid level is. I guess my point is that if there is air in the reservoir after you shut off the engine, replace the o-ring.
I did this on my Sisters RSC, my TL and my wifes Pilot, and it cured all 3 power steering problems.
#248
I picked up my 2005 tl 3 weeks ago in California. Drove it around down there for a couple of weeks, no problems. Drove it 1200 miles to Washington without a hitch. Then, very next morning, 40 degrees and damp outside,started up the car and the noise started. It has been that way for 2 weeks now, goes away after a couple of miles,after warming up I presume.
Having studied this thread, I just started the vehicle and noticed a change in the tone of the sound when turning the wheel. Also, I checked the PS reservoir before and after starting the vehicle. The ps fluid in the reservoir went from flat to frothy.
one more note, my p/s fluid is right on the "low" marker
I am visiting Acura in Tukwila on Monday to have the p/s hose replaced under the service recall. At that time I will request that they "throw in" the red o ring replacement. I will update you on Tuesday.
Regarding Rockstar's non p/s problem. Did we establish if Rockstars noise goes away after warm up, or is it continuous?
Also, sorry if a dumb question, but will dealer replace the P/S fluid as part of the free recall?
Many thanks to Majofo and everyone else who has contributed here.
One more note, my p/s fluid is right at the "low" mark on the reservoir
Last edited by nearpost; 02-04-2011 at 02:22 PM. Reason: extra point to make and other
#250
At this stage I am not certain if I have an o ring problem, because I heard no noise this morning when I started the vehicle. It could be that the noise was simply due to my p/s fluid being 1/4 inch below the minimum marker on the reservoir. Of course non of this explains the frothiness I observed in my reservoir last week.
This morning I dropped the car off at the body shop (another tale of woe for another thread). They also do mechanical, and will be changing my oil. I have asked them to check the vehicle out for p/s leaks, as the dealership did not comment on that when they changed the hose.
I will update later.
#251
Dealer replaced the hose noted in the recall letter, and refilled my p/s fluid. It had fallen just below "low", and may have been leaking. They declined to replace the red o ring discussed in this thread.
#252
PARTS INFORMATION
Power Steering Feed Hose Kit:
2004 TLs: P/N 06535-SEP-305
2005–06 TLs with M/T: P/N 06535-SEP-305
2005–06 TLs with A/T: P/N 06535-SEP-306
2007–08 TLs with A/T: P/N 06535-SEP-307
(Contains P/S feed hose, P/S pressure switch
O-ring, P/S pump inlet O-ring, and all bolts, nuts,
and gaskets needed for the repair.)
10. Replace the P/S pump inlet joint O-ring:
• Remove the inlet joint from the pump (one bolt).
• Remove the O-ring from the inlet joint.
• Lubricate a new O-ring with clean P/S fluid, then
install it on the end of the joint.
• Reinstall the inlet joint,
Go to this link and follow the instructions. Then scroll down to the TSB link, print it out and take it in with you:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
#253
Thanks I Hate Cars, and a special thanks to nfn squared!!!.
I read your posts 5 minutes ago, and got straight on to acura. My contact had gone home for the day, so I spoke to another service rep. This rep assured me that the O ring would have been replaced.
He even knew exactly which o ring was the culprit.
I can only assume that yesterday, when I pointed out to the first service rep, the o ring I wanted changed, (I even produced that handy picture from page 2 of this thread), he wasn't listening to me, or did not know what was in the kit that would be used.
No wonder she started up nice and quiet today. nfn squared, I was about to run out to the car and check the color of the P/S fluid, but forgot I dropped it off at the body shop earlier, so I will check it's condition when I get the car back. At this stage I am willing to bet they did pour in brand new fluid, as the mechanic is not the one at fault here. Car came back nicely detailed too!
edit:
Ha! just looked on the free of charge receipt. 2 bottles of power steering fluid were used (total 24 oz). Presumably that is sufficient to fill an empty system.
edit:
#254
Some service writers aren't worth the ink they use to write with.. I'd bet half of them don't know shit about cars.
#255
The TSB allows for up to three 12 oz bottles of PS fluid.
There have been cases where dealerships invoiced Acura for all 3 bottles of PS fluid, but put the old fluid back in and just pocketed the $$. You should still check your fluid and not rely on the invoice. Sounds like so far you're a victim of service department cluelessness. Make sure you're not also a victim of greed....
#257
Thank you for the DIY, 69 cent + my free labour.
Before the fix, it whines and the steering is freaking heavy when the wheel is not rolling, after the fix, it is significantly lighter, but still not as light as original, any thought?
Does changing out the old fluid helps, purge any possible air in the system?
#260
Ok so i just changed to the orange o-ring, since my car is at a complete cold startup it doesn't whine while idling, but it does slightly whine when I turn the wheel.
So my question is, is it supposed to stop the whine instantly right after it's replaced, or does it take a little while? I will wait until tomorrow to see what the cold start up sounds like. Hopefully it won't be as loud as before... I also hope I don't have to change my PS pump =/
#263
got my car back from the bodyshop last week. I checked the power steering fluid, and it looks pretty clean, sorry I can't be more precise. Run's great though, no whining in the morning.
#266
My car started to whine last week. Searched this forum and found this thread. Went to the Honda dealer for the o-ring, $1.04. Changed the o-ring this weekend, noise is gone. Thanks for a great DIY.
#267
Anthracite Trend Setter
Would appreciate some help diagnosing my problem. I have the famous power steering whine that is going around. Starts up on cold days (very loudly) and goes away as the engine warms up.
Car went in to a local mechanic recently for other work. I provided the orange Honda o-ring and the instructions on page 1 of this thread. He claimed to make the switch... no change. Honest guy, no reason to doubt him.
Checked a couple days later and the power steering fluid was at the low level (don't think mechanic added to it). Bought Honda fluid and filled it to the top line last night. This morning... whine is still there.
There is no fluid noticeable or leaking around the black elbow where the o-ring goes. I think the fluid may be leaking (somewhere), but it's hard to tell as it is winter here and I have no garage.
When I turn the engine on, little bubble appear in the fluid from the inlet on the right (facing the engine).
I have not been able to take bolt off to double check the o-ring. Need to borrow the proper tool from a friend. Don't have 10 mm wrench handy.
Anyone have thoughts on what they think the diagnosis is? Where else should I check for leaks and what is the best way to do so?
Thank you for your thoughts.
#268
i think it might be a good idea, spend about $50 bucks and do a flush and check the o-ring your self.
i followed this guide to flush my car
https://acurazine.com/forums/3g-tl-2004-2008-93/104-diy-power-steering-fluid-flush-761094/
side note, buy 3 bottles of honda fluid. and you can get the rest of the supplies at home depot.
the link list it, but it will be good to have a bucket, duck tape and some hose.
first i did the flush, while the power steering system was empty i changed the o-ring. the one i took out shot out somewhere (i hope it didnt shot back in, but i doubt that was possible).
then i plugged everything back in and finished the 2nd part of the that link which tells you how to properly refill the power steering system.
my noise is gone.
my noise is gone.
#269
dealer wanted 475.00 for this repair new pump ,after reading this info he replaced the ring at my request!!! iwas still stuck with a $95 diagnostic fee!!!! for other issues he trumped up never going there again!!!!!!thanx for the diy info im .just paid of my 2005 wdp tl.dealer raylaks acura amherst ny
#271
Thanks acurazine!
#273
Thanks for posting! Now that the weather's warming up in NY...I'm not hearing this anymore. The stealership certainly wouldn't have done anything for me, despite being under warranty. They need to "experience" it all for themselves!
#278
like a cat caught in a vice.
http://www.youtube.com/watch?v=iy0twsphy40
VIDEO DIY
note: It won't always cause PSF to spill out. Seems like his PSF is old and overfilled.
http://www.youtube.com/watch?v=Wf-_qp1y4yc
PS = Power Steering, F = Fluid
This is not a mileage issue. It's an air leak related to the hardening of the original o-ring (loses elasticity). PSF leak is related to the high pressure PS hose recall or a bad PS Pump / seal.
moreace (09-27-2011)
