DIY A-105: Power Steering Whine fix
#361
BC.. did it work for you?
#362
AZ Community Team
Received 7,771 Likes
What's that? The O-ring/whine or the "flush"?
Not sure about the O-ring 100% for sure yet. Hasn't been cold enough. BUT there was clearly less air. With the black o-ring I had a very little bit of "foam" in the resevoir. After - with the orange o-ring there was ZERO foam.
The "flush" seemed to work fine too. Kind of like an ATF drain and refill. Suck out as much as possible; start up and work the wheel a few times; suck that out; partial refill with (cheaper) Honda fluid; repeat. Fill with Amsoil PS fluid; crank the wheel back and forth several times; top off the resevoir.
At the end, what's in there now is clearly MUCH cleaner than what I took out at the beginning.
Alls well that ends well, I guess.
#363
2006 TL
Thanks for the tip, sadly if i used anything from the kitchen my wife would have my head on a pike! But i get the general idea, I'll look for non-kitchen tools to be safe.
When I drained my reservoir, I finagled a shallow dish (called a ramiken) into the spot next to it against the frame rail. Then I pulled the reservoir up and moved over the tray. I then unplugged the suction hose and let the fluid spill into the dish. Once it was near full, I plugged the hose back in and dumped out the cup. I think I had to do that 2 or 3 times before I could just remove the reservoir and clean it out.
Once the reservoir was out, I plugged a long tube into the return hose and ran that to empty bottle (large 2-liter or better). Then I started the engine and turned the wheel back & forth till became impossible to turn at all. Have someone hold the hose and bottle because it fills up quite a bit and there is quite a bit of force pumping that fluid around.
Filling it back up requires you fill the reservoir, then start the engine and turn the wheel. Shut it down and do it again (reservoir will be low again). Repeat until the reservoir stays full.
#366
You should be able to buy it for less than $1. Call around.. or acuraoemparts.
#368
Sorry bro.
#369
AZ Community Team
#371
AZ Community Team
Yes. You might have a short drive and recheck it. If it's still low, definetly add some fluid.
ILLustriousUA6 (12-27-2011)
#373
takin care of Business in
Received 4,732 Likes
^^^ after the oring fix, you should not get bubbles....
bubbles basically mean there is a air leak where they shudnt be one....
This can be caused due to Orings/leaks/etc or very low fluid levels....I suggest adding some more fluid asap....
#375
AZ Community Team
#377
You lose some fluid when you remove the hose to get at the ring. When done with the swap, open reservoir and refill to normal level. Turn on car, and cut wheel from one side to the other a few times to circulate the fluid. This is how you bleed a p/s system.
ILLustriousUA6 (12-28-2011)
#382
bump..
#383
Power steering problems
Hello Acura TL Owners,
I joined today and got my question answered regarding the power steering problem. Parallel parking is a nightmare. I took my car to the dealer where I purchased my 2005 TL Acura to find out why does my car whine. I was told it was because of the cold weather. Well lately, it has not been cold and I still here wheezing and whining. I am not a mechanic and I feeling the dealing is going to charge me an arm and a let to fix the problem.
What do you recommend if I go to the dealer to get this problem fixed now that I know that it may be the "O-ring" or the PS pump.
Thank you
Thank you
Kallee2012 (01-01-2012)
#385
AZ Community Team
It's 10 minutes with the right tools. If you don't have a small 10mm wrench or socket to get at the bolt it is MUCH more than 10 minutes.
Don't ask me how I know.
As far as Kallee2012's "How do I know it's the O-Ring" question: Check the posted video. Run the car, turning the wheel lock-to-lock a few times (park it on a couple pieces of cardboard to make this easier). Turn the car off and look inside the PS Fluid reservoir. If the o-ring is bad, there will be some foaming in the fluid. There should be NONE. If you have any at all, you're getting air in the system and that will cause noise.
Also, there is a Power Steering hose recall for your car. If that has not been done, get it done. Replacement of the O-ring is part of the recall repair.
#386
^^^good call.
Yeah, I guess I sometimes take for granted that for the most part, I DO have the right tools. I tried with a small socket and couldn't get the ratchet in...to me, it was only accessible with a craftsman 10MM wrench.
And this definitely goes wrong on all of em...a friend of mine stopped by with an 07 TL...complained of the same noise. I had recently rebuilt my ps pump (kinda) and had all the old o-rings laying around, including this orange one that I had already changed out once before about a year ago (so needless to say it was still good). With a slight buzz and the wrench I was able to swap it in and out for him in 10 minutes. Problem solved.
J.
J.
#387
Yep.. having the right tool is important. That's why if you see an odd looking tool, add it to the collection. At some point, it'll find it's usefulness.
#388
You can never have enough tools.
#392
AZ Community Team
Why would anyone need to pay for this?
Nearly every 3G Acura built (a few TL-S's and late '08's excluded) is subject to the Power Steering Hose Safety Recall. The replacement of this o-ring with the new orange o-ring is a part of that Recall.
If the Recall has not been done, get it done and make sure they replace the o-ring.
If the Recall has been done, but done improperly with use/re-use of the black o-ring, take it back and make them fix it properly. If they do not, file a complaint with Acura Corporate and the National Highway Transportation Safety Admninstration (NHTSA).
The Orange O-ring was an availble fix for PS whine on 4/2/2009; the PS Hose Recall, which includes that O-Ring replacement, was issued 3/20/2009. In other words, the Orange O-ring has been the available part for virtually the entire life of the Recall (all except ~13 days or so).
You can reference the Recall and TSB via the link below. Be sure to follow the access instructions at the top of the post before opening the TSB's (08-016 & 07-060).
TSB Page Link: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
#393
TSB Page Link: https://acurazine.com/forums/showthread.php?t=613659
#397
I just fixed this on my car last night. The part was .87 cents from dealer. Took about 10 minutes. Sure enough the dealer who did my recall never replaced the O Ring like the recall stated. Hence why the TSB was issued. Replaced the old brittle black O Ring with the new red one. Car runs perfect.
#398
Found this thread last Wednesday after we got a bit of a cold spell in FL and mine started whining like crazy. Went to Honda this weekend and got the ring for $.72 with tax and got it replaced. (believe what everyone else says, that little 10mm bolt is a nightmare to get at) Took me about 15 minutes and when I started it up Sunday morning, the whine was completely gone. I really wasn't thinking something that simple could solve what I perceived as a big problem. Thanks everyone for supporting this forum!
#399
I know this is an old thread but anyone know if you need to replace both o rings, I replaced the inlet o ring yesterday let the car sit for 4 hrs got in the temp read cold and no whine, so I thought my problem was fixed but this morning when I go to start my car up the whine returned! but goes away right after warm up!.......any other tips before I give in and replace the pump????
Thanks guys!
Thanks guys!
#400
^^^ did you flush out your fluid ? is your fluid low ?
