Crunch in 3rd
Crunch in 3rd
Does anyone have this problem? when my car is cold and i put it into 3rd i get this crunching noise. what is that? been hearing it for a while but never really payed it much mind. started to mod now dont wanna risk anything.
If it's only crunching when cold then possibly a fluid issue. I see you have an 04 have you ever changed it? Also our TL's have the 3rd gear issue and some are worse than others. Some have changed to the GM syncromesh fluid and have had excellent results with it. Check this forum for the list of TSB's (It's the sticky thread at the top) and read up on the 3rd gear problem.
Go to your nearest GM dealer and buy the GM Syncromesh Friction Modified fluid.
I changed mine out to this about a month or two ago and it had fixed the problem 100%. Matter of fact, it feels like a brand new tranny. It will reduce the wear of your gears.
Its like $15 a quartz and you will need 3 bottles.
shift confidently again
thats what the dude at the gtx oil change place told me. he said the oem oil is too thin. he had the same problem with his 2007 honda civic si. told me that he changed it now it flys!!! just got my stage 2 clutch!!! im soooo ready, going to gm tomorrow!!
Registered Member
The proper name for the GM product is General Motors Synchromesh Friction Modified fluid and the part number is 12377916. You'd be surprised how many parts counter people at GM dealers have never heard of this stuff.
Registered Member
Pennzoil synchromesh works just as well and doesn't cost much. redline MTL is also good stuff, amsoil synchromesh also is good from what I've heard. GM stuff you pay for the name. I just had the 3rd gear synchro fix done under warranty o my 05 TL 6MT and they filled it with the Honda stuff and its like butter cold or hot. Doesn't get stiff until its about -10 F or colder. Then again I don't know of many manual trans cars that are happy at -10 F at first startup.
ima go with the gm stuff no disrespect moto. if everybody is saying thats the fix i can deal with the $45 bucks for the fluid!! lol!! i wish i still had warranty, that would be sweet right now to go get it fixed!
Not all TL's. My '04 has been pristine in the transmission/clutch/shifting department since I bought it. Yes, I did my first transmission drain and fill at around 15,000 miles and use the GMSFM fluid. But I never experience any of the problems others have reported with my transmission. It has been perfect.
Yes I know not all have the problem, I was just puting the possibility out there.
Registered Member
I would bet most manual TL's do not have these problems with their transmissions. We only think they do because members of this website who have had the problems tend to report them.
That is a pretty good point now that you mention it as before i bought my car the reliability ratings were great. Also before i joined here i never heard about the 3rd gear problem. I'm lucky that mine happens only once in a blue moon so once the rain stops and i don't have work i'm gonna change the fluid out to the GM stuff.
Even if you dont have the problem, the $45 is well worth it. It makes your shifting a hell lot smoother.
It might not happen now, but when u start encountering it, it might be a little too late. ( as in damages has already been done).
Registered Member
Just a little piece of info for your casual reading.
I just bought a '06 w/ 6MT that came off-lease. Sure enough, after driving it for a couple days, I had trouble selecting 3rd. Called dealer (Bloomington MN Acura / Subie), and they will be replacing the 3rd gear assembly per the TSB. They were familiar enough with the problem that no verification was required (this is in warranty for this particular vehicle).
I had a similar problem with my S2K, though it involved 2nd gear. I get the impression Honda (or whichever sub is making the transmission) is having difficulty controlling the process. Not sure on my S2K whether the root cause was a bent shift fork or a synchro, since they replaced both during the tear-down. I expect similar results here.
My advice would be if it's just notchy, try the fluid swapout, but if you actually have trouble selecting the gear or it pops out of gear, go for the rebuild. If you are out of warranty, contact American Honda for goodwill consideration as this is obviously a design defect impacting many vehicles across several models. Keep in mind too that the drivetrain warranty is longer than the bumper-to-bumper.
I just bought a 2005 with MT. I am having difficulty selecting third gear. I find that I have to really line up the gear shift in the center, and push in slowly and gently or else it will refuse to let me put it in or will pop back out after I select it. I am glad to hear this is a common problem, because I have a warranty! What is happening here? Thanks
LIST/RAMEN/WING MAHSTA 짱
I prefer doing the fluid change rather then the stealership going in there and possibly doing something to harm the car. People who've let the stealerships replace their synchros have reported the same problem again after getting their car back.
You can go to the stealership and get the 3rd gear synchronizers changed out. OR, you could buy 7 bottles of the GM stuff, and change out the fluid (~ 2.3 qts/change). Do a total of 3 drain/fills. I'm at 43k, and I've done the 3x drain/fill twice already.
Also, I had the synchros replaced under warranty. The problem has not recurred. I have had not other issues (no problems w/ reverse, disconnected harnesses, etc.).
If the car is under warranty, and the problem is well-understood (now), with a TSB, I would be reluctant to let it go out of warranty. I would guess that the early recurrences of the problem occurred when the dealer replaced the gear assembly and synchro pack with a similarly out-of-tolerance replacement part, before Honda understood the issue.
I know people have had good results w/ just the fluid - but you're asking to get gooned if you have a problem down the road. You're also masking the issue. A properly designed and built transmission doesn't pop out of gear or reject a gear selection. Completely understandable if you just don't have confidence in the dealer or you're out of warranty...but come on...I would estimate that the dealer that did mine has done dozens. This is not an uncommon issue, and disassembling a constant-mesh transmission, while not trivial, is far from rocket science (and obviously way simpler than an auto). Just my $0.02.
mlody
12-04-2019 02:11 PM
emailnatec
29
09-28-2018 04:27 PM
1998, accord, acura, bloomington, change, friction, gear, gears, geo, gm, gmsfm, metro, modified, rebuilt, synchromesh, synchronizer, tl, transmission, xfi
