Cruise control does not engage
Old Oct 31, 2011 | 06:39 PM
maxpsi's Avatar
Question Cruise control does not engage
(6mt 06TL) Cruise control stopped engaging out of nowhere. No change made. Worked one morning and didn't work the next. Cruise on/off button lights up to enable cruise set, but cruise doesn't engage and light for engagement doesn't light up. I'm getting continuity on the set switch. The brake pedal switch seems to work fine and brake lights come on. Clutch pedal switch is also operating correctly. I wouldn't think anything happened to the wire harness. I tried unplugging a taillight, but that didn't do it. I also tried lightly tapping the brake & clutch pedal while trying to set cruise, but I had no luck there. I don't think it has anything to do with the clutch or brake pedal switch because I pulled up on the pedal while trying to engage cruise. The brake pedal switch has the correct continuity on the pins, and I can't start the car without pressing the clutch pedal. Both switches work.
Old Nov 1, 2011 | 06:10 PM
maxpsi's Avatar
No. 13 fuse isn't blown. The horn and speedo works. The no. 18 fuse under the dash isn't blown.
Old Nov 1, 2011 | 06:16 PM
maxpsi's Avatar
Looking at the electrical diagram, it looks like the horn switch shares the power with the cruise combination switch. So, if the horn works, the combo switch is getting power. I'm getting continuity where needed on the combo switch, so I know the switch is good. The signal leaves there into the gauge cluster to light the indicators and then onto the Ecu.
Old Nov 2, 2011 | 06:26 AM
maxpsi's Avatar
There has to be a continuity issue between the combo switch and gauge. Maybe it's the cable reel?
Old Nov 2, 2011 | 04:29 PM
maxpsi's Avatar
Clueless here. Effecting checks out after leaving the steering wheel out through the cable reel. Therefore, that indicator light on the gauge assembly should be lighting up and the cruise should be working UNLESS something is cancelling it out elsewhere. I give up....for now. I'm used to not having cruise control.
Old Nov 2, 2011 | 07:19 PM
jb879123's Avatar
04 6MT with the same problem...
Old Nov 3, 2011 | 05:45 PM
maxpsi's Avatar
Let us know if you find the problem. I'm going to throw holy water on mine.
Old Nov 3, 2011 | 08:40 PM
jb879123's Avatar
that was my next option too
Old Nov 13, 2011 | 03:49 PM
maxpsi's Avatar
So, out of nowhere, my cruise control started working last night. I've done nothing to the car since my last post other than the power window reset procedure and hitting the rev limited once while entering the freeway. Weird....
Old Nov 13, 2011 | 04:37 PM
jb879123's Avatar
so maybe a short in that clutch wire? I've got the 2004 TL repair manual, which has a troubleshoot for cruise control not working. PM me if you want the PDF.
Old Nov 14, 2011 | 10:43 AM
maxpsi's Avatar
I have the Helms manual in PDF. That's what I was using for diagnosis. Thanks though!
Old Nov 14, 2011 | 10:45 AM
maxpsi's Avatar
If the clutch switch shorted out, wouldn't I be able to start without pressing he clutch?
Old Feb 13, 2012 | 05:55 PM
maxpsi's Avatar
It looks like it was the clutch switch. Any movement or vibration would disengage the cruise control. I adjusted the switch so that it's being pressed farther in when the clutch pedal is disengaged (at rest).
knight rider
Mar 4, 2016 08:59 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
adreano17
Sep 29, 2015 08:48 AM
Froid
Sep 27, 2015 06:16 PM
