Cracked my tranny
Can I use a 08 base model tranny in my 08 type s well it wire up right or is the connector different
Yes.
So the tranny r interchangeable just trying to make sure before I buy one the base model and the type s model have the same automatic tranny and connetors and mounts
correct ? |
Let's put it this way-
'08 Base/'08 Type S: Trans case the same TQ case same Valve body the same Diff assembly the same Interchange indicates the 3.2 base and 3.5 the same Guess you're good to go |
Thank you was trying to make sure before I tryed to put a another one in
