Correct Part Numbers For 6MT Motor Mounts?
I need to replace all motor mounts and am having a bit of trouble locating the correct part numbers since Del Ray and OEM Acura Parts differ slightly. I have an '04 6MT and based on info I read here on AZ, I will need a torque dampener. Are these heat shields necessary? I saw that the the passenger side was completely torn and I can remove it by hand without any effort at all.
Motor Mount Part Numbers
Front 50830-SEP-A12 or A13
Rear 50810-SEP-A12
Side 50820-SEP-A11
Heat shields
50839-SDB-A01
50819-SDB-A01
Torque Damper
50843-SEP-A00
Is there not a heat shield for the front motor mount?
I have a ton of work I need done that will probably end up costing me $2,000. I'm also buying a new rack and pinion for $435. Besides this, will I need new boots if the ones I currently have are leaking? Tie rod ends? I put the car on jack stands and grabbed the front tires at 6 and 12, and 3 and 9, trying to move them, but there was no play at all so I don't think I need tie rods or new ball joints. Thanks everyone
Rear 50810-SEP-A12
Side 50820-SEP-A11
Heat shields
50839-SDB-A01
50819-SDB-A01
Torque Damper
50843-SEP-A00
triax37 (04-24-2015)
Head a da Family
For the front mount:
Fits 04 08 Acura TL Honda Accord 3 0 3 2 3 5L Front Motor Mount for Manual A4569 | eBay
and Rockauto.com for the rest of them. That's how I went and they work just fine.
Went all OEM. Just dropped about $1,000 in parts alone for new compliance bushings, LCA bushings, 3 motor mounts with a torque damper, and a rack and pinion. Going to install the front and side motor mounts myself, but man, should end up costing nearly $1800 after labor for everything else installed.
Head a da Family
darksky
09-05-2015 03:11 AM
