Confused on which brake pads I have, HELP
Ok, so I noticed my brake pads squelling like crazy recently. I assumed it was either the pads or that one service bulletin I have read. They check it out and tell me I need to change the brake pads and tried to charge me $400 dollars for it. Keep in mind I had just bought this car used (acura certified) just 13k miles ago and I already have to change the pads!! I politely decline and am going to change them myself. Ok, so the deal was I bought this car used from the dealership and have no clue what pads I have. I don't have an A-spec TL, I have a 2004 Manual transmission tl w/ navigation. The dealership told me I had upgraded sport brakes w/ bigger rotors than normal. Does this mean I need to buy A-spec pads? If so where can I buy cheaper pads, I noticed the A-spec front pads were like 170 from the dealership. I am not looking to Auto X here or anything, I just want to use my car for daily driving. If there are good aftermarket pads for cheaper I wouldn't mind getting those instead. Anybody have a link on where I can get some replacement pads? Thanks!
Eric
Eric
Ok, so I did some research on this forum and also called the acura dealership. I found out that the manual pads are different from the automatic pads and that the A-spec pads were the same as the normal manual TL pads. The dealership priced them at 200.07 dollars for just the pads, is there anywhere I can get these for cheaper? According to the acura dealership there is no aftermarket pads, but I think that is just B.S.
Contact Tim at 1-888-RAY-LAKS or hondacuraworld@aol.com. He's also availabe on the instant messenger.
http://replacement.autopartswarehous...%20Set&dp=true
Just a 5-second quick search on Google shows that Bendix has a couple of different types of front pads for the Brembo calipers. An extended search would turn up more, I'm sure. But that's your job.
Thanks, I called them up and they quoted me 139.33 which was the cheapest I can find so far, but still rather expensive. Are there no decent aftermarket pads I could get for under 100? Thanks for the help guys!
Thanks Chuckdu for the response. I just went ahead and bought the oem pads for 139 from hondacuraworld and will do them myself. I am very impatient, hehe. If there are other cheaper alternatives out there please let me know. I don't think I would like the hawk pads if they squeal and according to a couple of people that I have talked to, they say that the Bendix pads wear out real fast.
Eric
Eric
I have seen a few different pad types on the web,
http://www.partsandaccessories.com/a...12&brandid=478
ebc makes a bunch, starting at $25.00.
http://www.brakeworld.com/catalog.as...=items&catid=2
Rotex gold kelvar, $125.00.
I would want something that gives less dust then OEM pads, I have not heard great things about ebc, but have not tried them.
I like the pbr/axxis deluxe pads, but I do not think they sell them for he brembo's.
Brett
Brett
I have Rotora 4-piston calipers on my '03, and the cheapest pads are 160 bucks and last only about 10k miles.
Welcome to the world of big multi-pison calipers.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
