Clutch pedal creak
Registered Member
Most likely it just needs some white lithium grease. Remove the plaster under cover to gain access to the pedal and the rod to which it attaches that goes through the firewall. Then spray a little white lithium grease on the rod and work the pedal a few times. This should solve your problem. If it doesn't, report back.
Had same problem in Accord I owned. I sprayed WD40. Worked great.
Veeeee Tec
Veeeee Tec
Didn't even need to remove plastic cover. Did a couple sprays and no noises. That creak was so annoying!
Thanks guys!
Registered Member
You're fortunate in this. I have to remove the under cover since I am not far from 6 feet tall and around 205 pounds. The space just doesn't lend itself to my body.
Last week my clutch developed this "creak" near the bottom of the pedal travel. I've applied white lithium grease a couple times now. While it seems to work initially, the problem returns after a day or two.
What does this mean? Is my master cylinder on its way out?
In the same boat as you. Dealer has "lubed" it twice now which takes care of it for a few days. When it is real cold (below 20F) it is smooth as butter. Otherwise if I have the creak/pop when pressing the clutch down.
SidhuSaaB
05-30-2020 12:40 AM
