Clunking noise when driving over bumps?
Old 03-03-2019, 03:56 AM
  #121
Coming to a city near you
Achance's Avatar
I think this is my problem on my 04 with 240k miles. My rattle and clunking sounds high in the front and on both sides (I think I hear it in the rear sometimes as well.) The sound at 4 min when he moves the upper control arm sounds like what I hear. It looks like too much work for me to change out. I'm trying to get a new car this year and it doesn't look like a safety issue so I'll probably just live with it. But since everybody says the stabilizer links go bad and are easy to change and cheap ($50). I'll do those this weekend just for something to do.
Old 03-03-2019, 09:06 AM
  #122
Chad05TL's Avatar
I am getting a more noticeable noise on the front drivers side of the car.
I already replaced every component that guy mentioned in that video. --sway bar links, upper and lower ball joints, and even inner and outer tie rods, and wheel bearing,.. But I have not replaced the lower arm bushing. But It's not hitting anything that I can tell. Only a tiny tare but nothing that looks bad.
Plus I just looked at my timing belt and waterpump Job receipt from 2012(64k miles) and I confirmed the tech installed a new Front and Rear motor mount and a "Right" motor mount.. I assume the right motor mount is the one on the upper passenger side. He did not list the OEM part #. Just a personal description.. yuk.
Presently, I have 93k miles.... (and still clunking)
Since I am more concerned with the drivers side.. (I mean recently, I have even heard it jiggle at times.. more than just a single-one-time clunk)
I really need to check out the "upper transmission mount" @ 3:25 and the Lower transmission mount @ 5:16
Old 03-04-2019, 08:12 AM
  #123
Iggy's Avatar
Don't forget to look at the sway bar bushings. Often overlooked, easy to change and cheap.
Old 03-04-2019, 08:17 AM
  #124
Chad05TL's Avatar
Ok I will check those. I saw those in the video, but I have never heard of a clunk coming from a sway bar.. Squeaking, Yes! Clunking, no. I have laid eyes on them, and never looked peculiar..so I dunno.
Old 03-06-2019, 03:39 PM
  #125
jimmyfu's Avatar
Front Sway Bar Bushings would require a subframe drop, no?
Old 12-17-2020, 05:58 PM
  #126
Carlos Munguia's Avatar
Fix?
Originally Posted by Amelite
Aha! I have the EXACT same issue. I'm going to replace my passenger side motor mount and I will let you know how it goes! Do you have any new information about this?
What ended up being the problem ?I'm having the same issues
02-25-2020 09:57 AM
marcelft
07-10-2018 06:17 PM
PortlandRL
09-14-2015 12:01 PM
1Lieutenant
4G TL Problems & Fixes
09-10-2015 08:39 AM
jliu6789
09-08-2015 08:02 PM
Quick Reply: Clunking noise when driving over bumps?
