Metal to metal rattle from sub area during loud base
Old 02-02-2017, 07:45 AM
mazen222's Avatar
When i have a loud base on, i get this metal to metal rattle from the rear deck of the car. As if there's a loose penny on a metal surface that vibrates with the base.
I did insert a few cardboard pieces between the rear glass and the rear speakers cover/shelf as that was also rattling, so that noise stopped.
The metal to metal was present before and still is. But now its more noticeable as i dont hear the other rattling anymore.
Any ideas?
Thanks,
MM
Old 02-02-2017, 07:46 AM
Received 16,260 Likes on 11,971 Posts
keep felting/covering the rear deck.
that is the source of the rattles.
Old 02-02-2017, 08:13 AM
Received 8,576 Likes on 6,626 Posts
https://acurazine.com/forums/3g-tl-p...deo%5D-614680/
Should have just bumped this thread with your last post in November
Old 02-02-2017, 08:19 AM
kbouchard1092's Avatar
Most common causes:
-Need additional Sound deadener to the rear deck.
-Add Neoprene foam or cloth to keep it rattling on window glass (or against metal deck underneath)
-GPS sensor on pass side of rear deck.
-Center Seat belt Bracket - there is a SB out there for this.
-Missing or broken clips in rear deck
