Chirping noise from belt area, only for first 5 minutes
I have done extensive searching in the forums for this issue, and while it seems to be widely experienced, the suggested fixes are all over the place: TSB 10-035 (replace air compressor bolts with thicker ones), replace belt and tensioner, heat shield bolt, etc. I have exactly the noise as the video posted in another thread:
Does anyone have experience with this issue, and what the actual fix that worked for you was?
Also, if I am thinking about this correctly, if the noise goes away without the belt installed it could still be the AC compressor belt issue or the heat shield bolt issue.
RCpilot
05-12-2016 03:04 PM
