Check Engine Light due to Pre Cat Deletes
Hey guys, whats the fix on getting rid of the check engine light that's now on all the time because of the install of the pre-cat deletes I made? I heard that you are supposed to trick the O2 sensor but do I need to buy a part for it or is there an alternative route to fixing it? Thanks for your help guys.
I had the same problem when I first installed my RV6 PCDs (v1) and contacted Richie. He went out of his way and sent me over a pair of custom defoulers which spaced out the secondary O2 sensors to try and make the computer happy. The defoulers are are "L" shaped and corrected the problem.
P.S. make sure you didn't damage the O2 sensors as well, which could be throwing the CEL as well.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
rockyboy
Jan 25, 2016 06:00 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
