Changed my clutch but having problems shifting into gear.
Hey guys, so i just got my clutch changed with an fx250 clutchmasters. It doesn't shift smoothly into each gear while its running. My mechanic was telling me that I need to upgrade the clutch slave cylinder because it doesn't enough pressure to disengage the clutch from the transmission because even with the clutch fully pushed down, CSC doesn't have enough force to push the fork that disengages the clutch. I was wondering if there's a performance CSC on the market that has more pressure? I'm new to cars so I'm not sure if what I typed made any sense as I'm interpreting what I understand and i don't understand all to well lol
Did the shop sell you on the fx250? If so, man up and tell them to fix the damn thing.
If not, try contacting one of the guys in this thread:
https://acurazine.com/forums/3g-tl-p...utches-906678/
They need to adjust the pedal because it is not diengaging the clutch as for an upgraded master cylinder you can use an EM2 and delete the clutch check valve in the slave
Ok, I'll give that a try, and are you talking about the master cylinders for civics? Thanks btw
Not that this has to do with the problem you're having, but did you also have them put in a new flywheel when they did the clutch? I speak from 1st hand experience when I say that!
im still using the oem fly wheel, as it was still in good condition, I just had it resurfaced and cleaned up. I didn’t have the money to buy a new flywheel and couldn’t find one in my area when I had money.
. I guess I didn’t do enough research, as I was going through the forums it seemed like clutchmasters had the best quality, live and learn 😅
Clutchmasters, Exedy, and most aftermarket clutch kits are merely repackaged LUK's as they were the OEM supplier to Honda/Acura for most of our clutch parts. This repackaging is rampant throughout the auto parts industry with fancier advertising/packaging designed to sucker people in. I think you've learned your lesson for next time.
thelastaspec
Jan 2, 2016 06:05 AM
vtak2nr
Nov 1, 2013 07:55 PM
psteng19
Oct 31, 2011 11:06 AM
vilcafor
Aug 27, 2010 03:06 PM
types1967
Apr 26, 2004 01:09 PM
