Center vents not working when turning on heat?
Hi,
06 TL with 110K miles. Lately, I noticed that when I turn up the temp to get heat, I do not get any airflow through the center 2 vents. However, the side vents all work fine. I feel the interior getting warmer and hear the blower. This is not an issue when the A/C is on. When the A/C is on, all vents work properly. I took it to a dealership and they said its a "air mixture motor" failure and its going to cost $270 to replace. The motor controls the "door" to switch between heat or A/C.
1. Is it a fair price? 2. Do these fail regularly? 3. Any other symptoms I should be on the lookout?
Thanks in advance everyone!
Mine does the same thing.... I have to manually adjust the mode to have the air blow out the center vents and Also adjust the fan to max otherwise it won't blow as hard on AUTO
rockyboy
01-25-2016 06:00 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
