Car slows when foot off the gas to coast
Hi everyone! So like the title says, when i take my foot off the gas around 40mph to coast to a stop lght, the car slows down a slight amount. Now when i put it in neutral to let it coast, its normal and the car continues at a regular speed. Its not a huge difference, but it is noticeable. What is the issue here? I read about resetting the computer to have the computer relearn a driving style and reset the usual shift points, so should i change transmission fluid and clean pressure switches and all that?
Thanks!
2005 Tl, Base Auto, 40k miles
Thanks!
Latent car nut
Received 2,005 Likes
What makes you think there is an issue?
that normal for any car, try do it on a bike and you will see it slow down much quicker than car. its just physics...
yes i realize this, this is my 5th car and the first car to do this. Its like its engine braking when im coasting, and slows down at a rate faster than normal that it would be if it was coasting in neutral
Latent car nut
You do realize that is what is supposed to happen, don't you? Try this, take your foot off the gas, then downshift to 4th gear, then to third; the deceleration will increase each time you downshift.
Latent car nut
n this case it's engine/transmission load braking and not necessarily just engine braking. When you're in neutral, you remove the load of the transmission gears and the engine itself
Long story long, it's normal..
If it bugs you, try applying a very, very slight amount of pressure on the gas pedal. You'll still eventually slow down, but I've found it seems to stop the downshifting from happening too prematurely.
DMZ (02-27-2019)
could it be Honda's grade logic he's referring to?
Latent car nut
The next question in this thread will be, "How come when I push the gas pedal to the floor my TL accelerates way faster than any car I've ever had; especially my Corolla? Is that normal?"
When you let off the accelerator the throttle body closes creating negative pressure (high manifold vacuum) which the cylinders have to work against. At that point the wheels are pushing the engine rather than the other way around so naturally you get a drag effect which slows you down faster. If you put it in neutral, the throttle body opens just enough to allow the engine to idle without restriction while the wheels rotate freely.
That's one of the huge benefits of a manual transmission (though you can do it with an auto, just not as easily). You can downshift quickly causing significant engine braking due to higher RPM's which helps keep traction when the tires are slipping. It's saved me on more than one occasion. I've done it in an auto as well but it's not nearly as responsive.
jeezus
AmirBillups
05-27-2011 09:40 PM
