Car problems due to AC?
Old Jun 6, 2011 | 06:19 PM
**WhItE-aNgEl**'s Avatar
Hey, so I've noticed For these two couple of days when I started using my AC , my car has been kinda wanting to shut off when I brake. I have an 06 Acura tl 6MT. example: I could be driving 45 mph and as Im
Coming to a stop the car kinda stalls it goes under 500rpms and then goes back to normal idle. It bounces down then back to normal idle. Or if im shifting down as i brake the car does the same thing. Any help is appreciated. Thank you.
Please note it's only with the AC on.
Old Jun 6, 2011 | 07:10 PM
maybe there's a vacuum leak?
Old Jun 6, 2011 | 10:32 PM
jwclements1's Avatar
similar with 04 auto. doesn't happen all the time, but idle gets too low (a bit rough) at a stoplight with a/c on sometimes then bounces back. hasn't stalled yet on me.
Old Jun 6, 2011 | 10:35 PM
csmeance's Avatar
Have you changed the battery recently or is your battery very old? If yes, you need to perform the Idle relearn procedure and possibly replace the old battery.
Turn the car to stall mode and turn off all the accessories (A/C, radio, heated seats, etc). Then turn the car on and let it idle for about 15 minutes (or until the radiator fan turns on). The car will relearn the idle so it knows the minimum RPM it must keep.
If you haven't changed the battery recently and it isn't that old you might have a vacuum leak.
Old Jun 7, 2011 | 02:21 PM
How can I check for a vaccum leak?
Old Jun 7, 2011 | 02:25 PM
after troubleshooting the battery, like csmeance advised, I would then check all hoses, making sure each one is connected
Old Jun 7, 2011 | 03:37 PM
Turbonut's Avatar
You can always use carb spray around the connections to see if the idle changes when spraying. Most likely electrical.
The idle relearn is a little more involved and not certain it will work properly without the HDS.
Turn off all accessories
Reset ECU with HDS
Turn ignition switch on and wait for 2 seconds
Start the engine. Hold the engine speed at 3000rpm without load (in Park or Neitral) until the radiator fan comes on, or until the coolant temp reaches 194 degrees F (90 C)
Let the engine idle for 5 minutes with the throttle fully closed. Note: If the radiator fan comes on, do not include its running time in the 5 minutes.
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
redman333
Oct 9, 2015 10:12 AM
jordanboi
Sep 5, 2015 01:33 AM
darknite123
Integra
Aug 30, 2015 03:00 PM
