Car continuously resets itself.
So seeing if anyone else has had this minor dilemma. I know my car continuously resets itself as it keeps asking for my radio code every 3-4 start ups, along with this it resets my trip odometer back to 0.0, their has also been an instance of my drivers side door lock not letting me unlock the vehicle for me to get out of. I had to use the key itself to unlock the car. I have a feeling it might be the battery as it seems to be the oem battery from 07. Ive checked the connection and it is secured in tight. Can anyone else chime in?
Nvm found it. Just in case here's the thread.
https://acurazine.com/forums/3g-tl-problems-fixes-114/why-does-my-07-tl-s-computer-restart-sometimes-906542/
Battery. Check voltage. If the voltage is good, check the posts and connections. If they're seemingly tight, remove them, scrub both the connector and post with a wire brush and reconnect.
Check startup voltage just to be sure it doesn't sink. If the battery measures low but holds a charge, you can also check the current draw while the vehicle is off. Might be a parasitic charge drawing the battery low, but more than likely a faulty battery following tough winter.
