car is completely dead Please help
Old Nov 14, 2018 | 03:33 PM
franktypes's Avatar
7th Gear
Unhappy car is completely dead Please help
hello everyone
I currently own a 07 tl-s and it has been dead no power at all , unless I turn the key and the dash lights come on
but I only hear a click no sound after that
I try jump starting and nothing still
please help
Old Nov 14, 2018 | 03:37 PM
get a new battery.
You likely have a parasitic draw from the Handsfreelink, if you do a search here, you'll see it is a HIGHLY common issue..
Old Nov 14, 2018 | 03:49 PM
franktypes's Avatar
7th Gear
And what happens if that doesn’t work
what’s the next step
I also noticed that the break pedal is locked and I can’t change to Neutral
Old Nov 14, 2018 | 03:50 PM
use the shifter override ..
It's the battery.
Old Nov 14, 2018 | 03:51 PM
https://www.google.com/search?rlz=1C...60.CGEPXO9cL90
Old Nov 14, 2018 | 03:57 PM
franktypes's Avatar
7th Gear
I took the battery to autozone and it said it was fully charge
does that even matter or is that battery just doesn't work no more
Old Nov 14, 2018 | 03:59 PM
... wait you said "dead no power at all"
then you say you turned the key and the dash lights come on.. Are you saying you don't have power or are you sayin you can't start your car?
Better information = better answers
Could be your starter as well if it's just a starting issue.
Old Nov 14, 2018 | 04:01 PM
franktypes's Avatar
7th Gear
sorry first time posting lol
yeah I cant start the car
its fully dead , I try jump starting the car and it still doesn't wanna start
when I turn the ignition key the dash and headlights come on but that's about it
Old Nov 14, 2018 | 04:07 PM
Time for a new starter then
Old Nov 14, 2018 | 05:14 PM
Jackass's Avatar
Originally Posted by franktypes
its fully dead
You do realize these two statements are complete opposites right? If it is fully dead, then nothing works. If the lights come on, the battery isn't fully dead.
I believe you meant to state:
"Help, my car isn't starting. The lights and stuff still come on, but when I turn the key, there is a click but not much else. The engine never spins or starts."
If that is the proper translation, this is less likely a battery issue and more than likely a starter issue or maybe ignition switch issue.
Old Nov 14, 2018 | 05:24 PM
Pair of TLs's Avatar
What did the AutoZone guys say?
time for a new starter then
+1
Old Nov 14, 2018 | 05:52 PM
franktypes's Avatar
7th Gear
sorry you guys
but it is hard doing any of those by myself ?
or is better to take it to a mechanic
Old Nov 14, 2018 | 05:53 PM
https://acurazine.com/forums/third-g...cement-853757/
Old Nov 14, 2018 | 09:41 PM
Cool Give it a shot
sorry you guys
What's the worst that could happen?
Old Nov 14, 2018 | 09:43 PM
It can't be more dead...
Old Nov 14, 2018 | 09:50 PM
Midnight Mystery's Avatar
Null and proud of it
Old Nov 14, 2018 | 10:36 PM
jkim4296's Avatar
One of my buddies has starter problems from time to time and he gets it to work by smacking it with a tire iron. If the tire iron doesn't work, then he uses a hammer. It's definitely not a fix, but if you ABSOLUTELY need your car to run some errands (or get yourself a new starter which I highly recommend), it might work.
Also, if it suddenly got colder where you are then that might what caused your issue. Your starter still needs to be replaced because a good starter shouldn't have problems in colder weather. If the weather gets a little warmer, try giving it a start.
Like I said, those might be some temporary options until you can get yourself a new starter. Good luck!
Old Nov 15, 2018 | 05:21 AM
nick04tl's Avatar
That is a good tip. I have used a prybar and hammer or screw driver and hammer to get starters to fire up one last time and get a car home or in the shop.
Old Nov 15, 2018 | 10:54 AM
Wink Here's a hammer--when I nod my head, hit it
Same. Key phrase is "one last time" 'cuz sooner or later it will stop being a fix and it will happen during an emergency.
I like my cars to start when I turn the key.
Old Nov 15, 2018 | 04:31 PM
DesertMistTL's Avatar
what you can do to get your car going is locate the starter and smack it hard. It'll temporarily unstuck the starter...
Old Nov 15, 2018 | 07:37 PM
Wink Or...
You could locate and replace it and put the hammer back in the toolbox.
Old Nov 15, 2018 | 07:52 PM
this guy knows.
Old Nov 15, 2018 | 10:56 PM
or smack it and drive it home
Old Nov 16, 2018 | 11:24 AM
that's implying he's not already at home.. and if so, what's your next bright idea ?
Old Nov 17, 2018 | 09:52 PM
cwood1388's Avatar
So you've confirmed the battery is good. The next thing you need to check is the connections to the battery. Make sure they are tightened and the wire connections are tight as well A common issue i see on many tls that emulate a starter issue is a corroded positive cable. If corrosion is present the unwanted resistance in the circuit wont supply enough amperage to turn the starter over. Sometimes you can get lucky and just clean the posts and terminal, others you have to replace the cable.
Hope this helps!
Old Nov 18, 2018 | 01:22 AM
Old Nov 24, 2018 | 11:53 AM
franktypes's Avatar
7th Gear
so the mechanic called and he told me that the fuses on under the hood are blown , he advise he put new fuses but they srill keep blowing
is it a short ? is that the reason why the car is not turning on ?
Old Nov 24, 2018 | 12:06 PM
Jackass's Avatar
If the fuses keep blowing, you have other issues you need to sort out before you keep chasing the no start condition. What fuses are blowing? Have you had any work or other changes done to the car recently?
Old Nov 24, 2018 | 12:08 PM
franktypes's Avatar
7th Gear
nothing yet it was running fine , till I started having electrical issues / while driving during the night the headlights will turn off and I had to move the cable that connects to the battery and fuse box so they can turn on again . idk its a weird thing its having
Old Nov 25, 2018 | 09:31 AM
DMZ's Avatar
DMZ
Head a da Family
hello everyone
Had that exact same problem 2 years ago. Turned the + battery cable needed to be replaced.
At this age it might be corroded internally where you can't see it.
juggalosblaze
Sep 11, 2018 12:45 AM
AllanR
1/2G MDX (2001-2013)
Jan 6, 2017 06:39 AM
esteef
May 1, 2015 12:13 PM
BrianC636
Jan 9, 2014 03:45 PM
shownfu
2G CL Problems & Fixes
Sep 9, 2011 03:42 PM
