car is completely dead Please help
hello everyone
I currently own a 07 tl-s and it has been dead no power at all , unless I turn the key and the dash lights come on
but I only hear a click no sound after that
I try jump starting and nothing still
please help
please help
... wait you said "dead no power at all"
then you say you turned the key and the dash lights come on.. Are you saying you don't have power or are you sayin you can't start your car?
Better information = better answers
Could be your starter as well if it's just a starting issue.
sorry first time posting lol
yeah I cant start the car
its fully dead , I try jump starting the car and it still doesn't wanna start
when I turn the ignition key the dash and headlights come on but that's about it
I believe you meant to state:
"Help, my car isn't starting. The lights and stuff still come on, but when I turn the key, there is a click but not much else. The engine never spins or starts."
If that is the proper translation, this is less likely a battery issue and more than likely a starter issue or maybe ignition switch issue.
You do realize these two statements are complete opposites right? If it is fully dead, then nothing works. If the lights come on, the battery isn't fully dead.
One of my buddies has starter problems from time to time and he gets it to work by smacking it with a tire iron. If the tire iron doesn't work, then he uses a hammer. It's definitely not a fix, but if you ABSOLUTELY need your car to run some errands (or get yourself a new starter which I highly recommend), it might work.
Also, if it suddenly got colder where you are then that might what caused your issue. Your starter still needs to be replaced because a good starter shouldn't have problems in colder weather. If the weather gets a little warmer, try giving it a start.
Like I said, those might be some temporary options until you can get yourself a new starter. Good luck!
I like my cars to start when I turn the key.
So you've confirmed the battery is good. The next thing you need to check is the connections to the battery. Make sure they are tightened and the wire connections are tight as well A common issue i see on many tls that emulate a starter issue is a corroded positive cable. If corrosion is present the unwanted resistance in the circuit wont supply enough amperage to turn the starter over. Sometimes you can get lucky and just clean the posts and terminal, others you have to replace the cable.
Hope this helps!
Hope this helps!
so the mechanic called and he told me that the fuses on under the hood are blown , he advise he put new fuses but they srill keep blowing
is it a short ? is that the reason why the car is not turning on ?
If the fuses keep blowing, you have other issues you need to sort out before you keep chasing the no start condition. What fuses are blowing? Have you had any work or other changes done to the car recently?
nothing yet it was running fine , till I started having electrical issues / while driving during the night the headlights will turn off and I had to move the cable that connects to the battery and fuse box so they can turn on again . idk its a weird thing its having
At this age it might be corroded internally where you can't see it.
juggalosblaze
Sep 11, 2018 12:45 AM
esteef
May 1, 2015 12:13 PM
shownfu
2G CL Problems & Fixes
Sep 9, 2011 03:42 PM
