Can't find DIY Axle replacement
Old Jun 6, 2011 | 01:42 AM
Toddy's Avatar
Registered Member
Anybody have a DIY for Axle replacement? My passenger side is shot and needs to be done. I tried searching but it's dragging ass and not bringing up what I need. Or maybe someone has the Tech Scans. Thanks
Old Jun 6, 2011 | 03:31 AM
paperboy42190's Avatar
im looking for the same thing, if someone has it, it would be greatly appreciated
Old Jun 6, 2011 | 07:47 AM
Turbonut's Avatar
Not really a DIY, but has the items that need to be addressed. Just keep in mind that the right axle isn't removed from the trans, it's removed from the intermediate shaft. Also, the FSM notes to drop the exhaust pipe, but it seems that this isn't necessary as the job can be done wihtout this step.
https://acurazine.com/forums/3g-tl-2004-2008-93/cv-axle-install-question-742048/
Old Jun 6, 2011 | 11:02 PM
Toddy's Avatar
Registered Member
Anybody know if the Honda Axle shaft will fit since nobody has the passenger side for a 6spd
Old Jun 6, 2011 | 11:56 PM
csmeance's Avatar
I will have the scans posted in a little bit from the service Manual
Old Jun 7, 2011 | 12:00 AM
Toddy's Avatar
Registered Member
Thank you sir.
Old Jun 7, 2011 | 12:18 AM
csmeance's Avatar
here is the link:
https://acurazine.com/forums/showthr...8#post13001718
Garage A-128!
Old Jun 7, 2011 | 12:25 AM
Toddy's Avatar
Registered Member
Awesome. Now lets see if I can find an axle. Emailed Raxles so hopefully they can get me one asap cause I have the feeling mine is going to let loose here in the very near future...
Old Jun 7, 2011 | 12:30 AM
csmeance's Avatar
A few members here tried aftermarket axles and they found out a few were pretty bad. Your going to find most of them if you search in the performance parts and modifications section.
Old Jun 7, 2011 | 12:50 AM
Toddy's Avatar
Registered Member
I haven't read anything bad about Raxles but I did read about the others. Ill look into the dealer. Too bad nobody makes some decent aftermarket axles for us. Acura OEM Parts hasone listed for $167 but from experiance with dealing with them their site gets hacked alot and the prices are typically wrong.
Old Jun 25, 2011 | 07:19 PM
ez12a's Avatar
the overexplainer
I'm thinking of undertaking this myself. I have the dreaded click click coming from the passenger side whenever I make a right turn (and a faint click when making a left). passenger side boot is torn and leaking some grease.
I looked up the part #44305-SEP-A02 for the passenger side axle/cv (not intermediate shaft). Does it come with the outer boot (closest to the hub/knuckle) attached or do you need to put that on yourself? Do aftermarket axles come complete (no messing with boots and grease)?
For the ball joints, when reinstalling do I just need to worry about getting the nut on and cotter pin or whatever? Does it need to be popped back in or does the weight of the car do that for you? I know improper assembly of a ball joint can cause catastrophic failure..
thanks!
Old Jun 26, 2011 | 06:58 PM
usmarinedelta's Avatar
Just a bit of advice from previous cars, when you buy aftermarket axles such as autozone and things like that, most don't come with the little rubber doughnut that absorbs some noise and vibrations. Just an fyi.
Old Jun 26, 2011 | 11:47 PM
Toddy's Avatar
Registered Member
thanks!
Well good luck finding an aftermarket 6MT passenger axle. Nobody has them. I tried every auto parts store and Raxles. Nobody has them. I got an OEM unit from AcuraOemParts.com for $167. It is a complete axle. Pull the old one out and put the new one in.
Old Jun 27, 2011 | 12:32 AM
ez12a's Avatar
the overexplainer
the "dynamic dampener"? gotcha.
hmm guess i'll go OEM.. what of the ball joint? When I reinstall is it simply as easy as putting the ball back in its seat and bolting the thing down? Does it pop back in on its own weight?
Old Jun 27, 2011 | 12:50 AM
Toddy's Avatar
Registered Member
I've always torqued the nut carefullyt to pull the ball joint back in so it goes in straight. The I backed it out and put the cotter pin in. Never had any trouble doing it that way.
Old Jun 28, 2011 | 12:18 PM
The correct way to re-attach the BJ and castle nut is to torque the castle nut to the lowest torque value, then align the castle nut with the pin hole by continuing to TIGHTEN. The manual says not to align the pin hole by LOOSENING the castle nut. That's why they give you a torque range of 58-65lbf-ft.
Step 5b and c on page 16-19 on the scans provided by the Mod above validates this.
$167 for an OEM axle is not that bad for a 3G TL. Especially when OEM axles for the CL-S6 are $636.00 each. Raxles makes a good product and they come with the damper for around $150+ each shipped. Raxles will only take OEM units as a core and they will supply the return ship labels. Mine looked like a work of art and were of very high quality. No foreign (china) components are used per the owner Marty.
thanks!
If you read and follow the instructions in the scans provided above, all of the questions you have will be answered.
Old Jun 29, 2011 | 01:57 AM
Toddy's Avatar
Registered Member
Thats what I thought especially since my local dealer was $80 higher than Delray was. Raxles said they do not have any passenger side 6MT axles available. I wonder if they will buy my old unit from me...
Old Dec 7, 2011 | 03:07 PM
mlody's Avatar
I hate to revive the old thread, but does anyone know if driveshaft replacement is covered by the power train warranty? My car needs the right one replaced (part number 44305-SEP-A02) and it is still within 6 years/70k miles, but my dealer told me that this isn’t covered. The warranty manual booklet says otherwise – quote: “Front-Wheel-Drive System Final drive housing and all internal parts, driveshafts, constant velocity joints, front hubs and bearings, seals and gaskets.” Does anyone have any experience with this? Thank you
Old Dec 7, 2011 | 03:45 PM
Toddy's Avatar
Registered Member
Bring your warranty guide with you when you talk to him. Also contact Acura Customer Support and tell them the issue you are having with your dealer and they should be able to help you
Old Dec 8, 2011 | 07:34 AM
mlody's Avatar
This is exactly what i am going to do. I have already called the Acura Customer Support and gave them the part number that is being replaced and the lady confirmed that the part number is covered under power train warranty plus all associated costs. I received a case number and was advised to refer to it when speaking with the dealer again if they refue to honor the warranty.
Old Jan 24, 2012 | 12:12 PM
trancemission's Avatar
Regions Leader
I have the clicking as well.....I just ordered a new drive shaft.
Ill be sure to take pictures and come up with a DIY for you guys.....
I dont think it will be that hard.....we'll see though
Old Jan 24, 2012 | 12:25 PM
Regions Leader
Just spoke with Acura....I called them to see (for what it was worth) if I was under any type of power train warranty....
He told me that the click Im hearing is from my tranny....he said I need to flush my tranny fluid........he said I shouldnt be running GM fluid in it
Im still going with the shaft.....right side doesnt look so hard
Old Jan 24, 2012 | 12:59 PM
ez12a's Avatar
the overexplainer
^yeah, what that guy said doesnt make any sense when the clicking only occurs when the wheels are turned. How is that even related to the internal workings of the transmission.
Old Jan 24, 2012 | 08:07 PM
Regions Leader
You guys know what size socket to use for the axel nut?
Old Jan 25, 2012 | 01:52 AM
Toddy's Avatar
Registered Member
I can't remember what size the axle nut was. I actually still have the clicking after a new shaft. I am not running the GM Fluid yet, changing it next week most likely, so I call BS on that part the dealer said.
Old Jan 25, 2012 | 07:20 AM
Regions Leader
wow, you still have the clicking? well that sucks...
if this doesnt fix mine then I have no clue what it could be....
my noise is loud when Im turning and on power.....but after i drive it a few miles it stops
Old Jan 25, 2012 | 03:19 PM
Toddy's Avatar
Registered Member
I only hear mine in reverse while turning. Replacing the axle did make it less noticeable. I'm going to replace the drivers side axle as well just in case.
Old Jan 25, 2012 | 03:26 PM
Regions Leader
Its 36mm for those interested......gonna head to harbor freight this weekend
Old Feb 7, 2012 | 03:13 PM
Sickboy722's Avatar
2006 Acura TL
Sound like a good thread to ask this question. The other day I removed my front passenger wheel and notice the drive shaft was leaking grease on my 06 tl and was wondering if it's normal or not? It seemed like a good amount since the inside of my wheel had alot of grease.
Old Feb 7, 2012 | 03:48 PM
Regions Leader
Does it look like its coming from the boot on the axel?
If so then that could be the CV joint
I just finished replacing mine last night. It was a bitch! But going back together it was damn easy.
I was going to post a DIY but there was too much shit I had to do
So if anyone has any questions about how, I would be more than happy to answer
Old Feb 7, 2012 | 04:08 PM
ez12a's Avatar
the overexplainer
yeah, look on the underside and you may need to look between the folds of the rubber boot to find a crack. Mine's leaking on the passenger side too.
trancemission, how long did the job take for you? First time trying the axle? What tool did you use for the ball joint? reassembling the ball joint easy enough? thanks!
Old Feb 7, 2012 | 06:02 PM
Regions Leader
It took me a total of about 4 hours I'd say.
Yeah it was my first time doing one. Being a mechanic I figured it wouldn't be that hard.
I used a puller for the ball joint. Those weren't the big issue for me.
what sucked was the axel nut, that was a fucking pain, I worked on just the nut for about an hour and a half
Getting the shaft out was challenging but I finally prevailed.
Going back together was cake......im so glad I did this......it solved all the issues I was having with my front end.
Old Feb 7, 2012 | 11:59 PM
Sickboy722's Avatar
2006 Acura TL
its coming from the rubber covering i would have to check again, ill take some pictures tomorrow and post it up, but what would i have to replace to get it fixed and how much for parts?
Old Feb 8, 2012 | 12:59 AM
Toddy's Avatar
Registered Member
You would have to replace the whole assmebly most likely. If it is leaking from the boot the joints are most likely contaminated. I bought my axle from AcuraOEMParts.com (Delray Acura) for $165 shipped to my house in 3 days.
Old Feb 8, 2012 | 11:59 AM
Regions Leader
OR you can support our vendor OEMAcuraPartsTim
which is what I did
Old Feb 8, 2012 | 12:38 PM
Slpr04UA6's Avatar
-------Tim-------
^how much was the part through Tim?
Old Feb 8, 2012 | 12:57 PM
Regions Leader
Its the same, I've known Tim for a very long time.
he's a great guy, in the 6+years I've owned my TL I've bought every OEM part from him
Old Feb 8, 2012 | 12:58 PM
PJ-Delray Acura's Avatar
Former Sponsor
We did hve an issue about 2 yrs ago with this, but everything is fine.
Old Feb 8, 2012 | 01:01 PM
Former Sponsor
Smile
which is what I did
Hey, we are a 'Premium' Sponsor of ACURAZINE. Check us out in the vendors section or see our banner ads.
Old Feb 8, 2012 | 01:06 PM
Regions Leader
My bad.....disregard!
Sometimes I type before I think.
