Can’t find out which are shift solenoid A and C having CEL and codes p0974 & p0980
Subscribe
I have been at this for sometime now trying to get answer on Reddit with no help (probably my first mistake) bought the 07 type S knowing it didn’t work, I connected my OBD scanner to tell me all the codes. It needed things like a alternator, starter, some other minor things and 3 shift solenoid codes. (P0966,P0974,P0980) along with a few other codes…. Well I replaced the dual solenoids that are on the side of the trans and replace the single one at the top. I have no idea which solenoids those are but the code P0966 has been cleared. The other 2 codes are still active and I have a blinking drive light. Car doesn’t go into any gears so I replaced the shifter (old one was broken) all I’m left with is codes P0974 and P0980 and
I just need to know what solenoids those are and where they are located. If anyone can help me please.
car goes into gears except drive I don’t know maybe i may have connected the shifting linkage to the new PCM switch Located behind the drivers side tire incorrectly?? I’m still learning and new to the Acura/Honda cars as my friend swears on his life these are amazing cars which is why I picked up the 07 type s. I haven’t even driven it but when the engine turns on it sounds amazing. Here are some photos for reference.
also when putting it in reverse it doesn’t move but the rpm goes to about 1.5 that’s not me pressing the gas.
