A/C question
A/C question
i noticed that the air coming out of the vents isn't coming out very hard like all of my other cars i have prievously owned. I have not been in another TL, so i don't know if this is normal or not. It still gets cold, just the air dosen't blow out like my wifes Altima.
When on automatic, the fan will adjust, but I've found that unless extremely hot inside the car, the fan runs on a lower speed than what I have been accustomed to. All our other ATC equipped cars have really roared when first started when interior hot. Having said that I have found that the TL will cool quite quickly and remain cool even though the fan operates at a lower speed. You can always adjust it manually to increase the blower speed.
standard questions.. clean cabin filter? does it not blow at all sometimes? fresh or recirculated air?
make sure your cabin A/C filter is clean.. if it doesn't blow at all sometimes then that indicates a bad blower motor. If you have it set on fresh air try switching to recirculated air.
Just changed cabin filter about 6 mon ago. I am thinking it is normal. I am used to nissans though. The a/c's in them feel like a leaf blower on your face. Thanks for the reply.
i should say though, that the little air coming out is very cold. the a/c in my 2005 is colder than some other 2009 cars i've driven, it just doesnt blow hard enough.
Registered Member
You people who are only getting a light to medium airflow from your dash vents when the fan is set to high should check your system out. I just now checked my '04 and on high, it blows pretty hard. You can feel it quite a bit sitting in the back seat from the front dash vents.
Registered but harmless
Received 1,149 Likes
I generally set my TL climate control on "Auto" and 71*F-- it works really well (even with record heat from Sunday-Tuesday here in Los Angeles), so I've never manually used the "Hi" setting.
On hot days, after the car has been started and running for a few seconds, the CC will spool up (in a refined graduated way, rather than instant-on) to blow high for a few minutes until the interior cools, then slows the fan speed to maintain the temp. When starting the car on a hot day, the A/C air flow can come out pretty hard.
On cooler days and when the interior is cooled, the A/C air flow is pretty subtle unless a vent directs air towards the face, which will get cold. I direct the vents away from body parts usually, except when it's really hot.
Registered Member
We are saying is that in auto the fan does not run at the highest speed, but cools perfectly. Very rarely is the fan running on the highest setting as it seems that you can always raise the speed manually. With the fan set on high manually, naturally it blows considerably harder. No problems with the system.
Sorry gentlemen for any confusion there.
Registered Member
If you really do have a problem with your vents properly opening (and this certain can and does happen), work them manually from one position to another several times while checking the vent openings. This did happen once to me last year and doing what I just described fixed it and it has never occurred since.
At times we actually moved the system to manual to change the air flow direction. Maybe SoutherBoy has a tip, manual in winter auto in summer!
Auto Mode.. ah c'mon.. details people!
I never use the Auto mode b/c it usually blows hard for an extended time. That would indicate to me that there is a possible issue if you guys experience the opposite & it blows hard when you manually increase the blower speed.. hmm..
No problem, just a misinterpretation. We leave ours on auto at all times, and can never complain about the quickness of cool down, or the efficiency of the heating system. The only problem I see as have others, is in cold weather, the inside cabin temp isn't maintained properly and the need for adjusting the temp setting up a few notches. There was a thread on this a while back.
All the ATC units I've had, including the TL, will have the fan motor at a lower speed after reaching the desired temp, meaning that the fan motor can always be increased manually. Not only will the fan blow slower, the recirculate door will open to draw in outside air which will also cause less noise. Absolutely nothing wrong with the unit, at least in mine, just normal operating conditions.
Registered Member
Here's what I have found to work quite well with my '04. During the off months, as in those months when I don't use my A/C, I never use the Auto setting at all. Plus I never use the defrost button. The reason I do this is because the Auto setting and the defrost will cycle the A/C. I have found that in cold or moderate temperatures, the manual settings work great and do exactly what I want and need them to do. I select whatever temperature I want, and most the time I use fan speed two or three. Then I use my Nav to direct flow to the locations where I want it to go. For defrosting, I also use the manual setting without the A/C (except in summer when necessary) and never have a problem clearing my windshield. My cabin stays quite comfortable and the system works very well.
During those times when I do use the A/C (not all as much as some, I'm sure), I always use the Auto setting because I have found it to do the best job in cooling the cabin.
I think he just meant the buttons next to the nav, not the touchscreen itself. However, you can control the airflow through the nav if you've done the climate control nav hack, not worth doing IMO.
Registered Member
The stock system will completely control you climate control. You can change everything from flow direction to fan speed to whatever settings you wish.
To change the flow from the floor to the dash just press the Activate voice command button you your steering wheel and say, "Climate Control dash". The flow will be directed to the center dash vents. Then say, "Temperature 62 (or 62 degress)" and that is where the system will set your temperature. Same thing with fan speed.
And my fault. I didn't mean Nav. I meant the voice commands... sorry people for the misdirection there.
Registered Member
I used my A/C Saturday evening for the first time this season (first time means actual use and not just running it for 5 minutes to exercise it). Outside temp was 95. I set it on 68 degrees and used the Auto setting. Happy to see all was well. I did notice that the cabin temperature came down quickly enough that after about 10 minutes, it switched from recirculate to outside air.
Only thing is getting used to the extra drag on the engine. Though very minor, it does pull the engine speed down quicker between shifts so I have to adjust my shift timing when the A/C is on. Such is the thing with small, low torque engines.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
