A/C freezing cold yesterday just blows air today
so pretty much what it says in the title is what's going on. Yesterday my AC was blowing freezing cold I get in the car today and it's just blowing air has anyone experienced this before? Where should I start?
CAD Guy
Well the easiest thing to check would be to pop the hood while the car is running with the A/C on and see if the clutch on the compressor is turning. If it is then you may have some refrigerant level issues or blend door issues, if not then you can swap the relay for the A/C clutch/field coil with another one in the under hood fuse box and see if that makes a difference. There is a chance you may have low refrigerant levels or its possible you have a field coil or clutch failing on your compressor. I had to deal with both last year on my TL, I was able to diagnose and replace the field coil myself, but shortly after I had a leak start in one of my lines and I took it too a A/C shop to get fixed.
Then if that still doesn't work and you don't want to start diagnosing it yourself, you can find a shop that specializes in A/C and have them take a look. Which really isn't as bad as people think, I paid like $75 for them to find the problem and they credited that amount into replacing the line (with an OEM part) that was leaking and recharging the system.
Knicee
10-30-2017 07:25 AM
bandits31
11-22-2016 06:42 PM
