Black Roof Trim Loose
can anyone advise how to re-secure the black roof trim which starts down by the windsheild? Only two clips near the sunroof and rear drivers door came loose. It looks like it needs to slide into place. I found a page out of the manual on the forum but it really doesn't explain how to secure only install reverse of the removal. It looks like i might need to push down and with a small screwdriver slide the plastic lock over.
Anyone done this before?
Vince
Vince
If you go to the back of tha strip by the rear window and take a block of wood and a hammer you can tap the strip forward and it will release off the "T" pin at the rear. Then take the strip and put the outer edge of it in the first clip and roll it to the middle of the car .. this will attach it .. do it with all 3 then have someone hold the back of the strip down over the "T" pin and you go to the front of the strip and push it backwards .. tap it if you have to.
It only moves a 1/2" or so.
I was trying to search the post I had showing this but the search function doesn't work.
OK found it ... you will need to scroll to the bottom for that part .
https://acurazine.com/forums/3g-tl-2004-2008-93/front-rear-door-panel-handles-wstrip-glass-window-regulator-removal-3g-garage-f-016-a-603296/
09-17-2015 09:01 PM
