Belt tensioner tq question
I'm replacing the belt tensioner on my 08 tl. How tight should this bolt be? If I really tq it down the pull won't move at all but if I go just past finger tight it spins fine but seems like it'll loosen and fall out...in other words..I'm stuck for now haha
Depending on where you purchased the pulley, have heard that certain numbers won't work as the outer washer
hits the pulley which seems to be your problem. You should be able to tighten the bolt down and not worry about
the pulley turning/not turning as the pressure should be on the internal sleeve.
I'll try again here in a little bit. See if taking that metal washer off works. Thanks for the reply, no BS haven't sleep at all worried I screwed our semi-new car up badly
33 ft-lbs
GoldnKnight22
04-28-2016 02:28 PM
Skier4lyfe303
02-18-2016 01:23 PM
