Battery Draining AND alarm not arming/chirping/lights flashing when locked
Old Jan 16, 2014 | 10:11 PM
awtix7's Avatar
Exclamation Battery Draining AND alarm not arming/chirping/lights flashing when locked
Hello everyone! I come and browse these forums every now and again, but first time posting and could really use some help. I've owned my 2007 Acura TL Type-S for 3 years now, and love it, except for this recent problem I have no idea where to start!
At some point a few months ago, I really don't know when or what caused it but my car STOPPED chirping as well as the lights going off when I locked the car with the factory remote. Not only that, but I recently realized that the car battery is slowly draining. If I drive the car within 24 hours there is never any problem, however if I don't drive my car for 2 or 3 days, the car is DEFINITELY dead. I have had this happen twice to me now so I have confirmed that there is a medium/slow battery drain going on. I remember when it first stopped chirping I thought that I had changed the settings to silent or something, but I have checked those settings in the HUD and they are all at default. I don't remember exactly when it stopped working, if I had taken it to get an oil change, or it just randomly stopped one day, etc.
A little more background on what I have tested from what I've read on here:
1. All the doors and the trunk switches DO in fact work, as when I am in the car the HUD display tells me they are all open/closed when tested, so it's not a stuck switch that isn't closing the circuit from the door/trunk.
2. I do have an aftermarket stereo. I am using a Line 6 audio unit with a JL Audio 900/5 with a W6v2 and some Focals in the front. I have checked that the amplifier is shutting off when the car is turned off, and it is DEFINITELY NOT on.
I don't know if these issues are separate, but I imagine that they are related. Please help me!!!!
Thank you so much.
Old Jan 16, 2014 | 10:17 PM
awtix7's Avatar
I will also add that when this first happened, I replaced my Stinger 1200 battery with a new one(because it was 3-4 years old and I thought it was the problem). So I have a few month old fresh powerful dry cell battery in there, so it's not some janky old stock battery.
Old Jan 16, 2014 | 11:53 PM
Will Y.'s Avatar
Registered but harmless
Check the status of the HFL(Bluetooth) unit as to your battery issue.
Check for a large draw 40 minutes after shutting off the car-- the HFL is programmed to stay active for 30 minutes after shut-off. If there is a large draw, it's probably the HFL.
You can also check the HFL status in the MID when the car has been running for a bit-- if the MID indicates the HFL is "booting up," the HFL is likely bad and draining the battery.
With regards to the chirp-- check the hood sensor: see tl.acurazine.com/forums/showthread.php?t=902348
welcome to AZ.
Jul 16, 2017 07:33 AM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
thegipper
Sep 28, 2015 01:01 PM
