Bad rear motor mount?
Old Nov 19, 2011 | 06:53 PM
2k6ATL's Avatar
Hey Guys,
What are symptoms of a bad rear mount? I recently purchased my 2006 Acura TL with 90k miles. The dealer said they replaced the front mount and I'm having vibration issues at stops so I'm assuming its the rear mount. The vac lines are plugged in as they should be and no fluid is leaking. So far I replaced the side engine mount and upper transmission mount. Suframe mounts are also new. There is definitely vibration in the steering wheel still. Any ideas?
Thanks,
Kevin aka 2K6ATL
Old Nov 19, 2011 | 10:39 PM
cipdagr3at's Avatar
HASTA LA VICTORIA'
on a scale 1-10 how bad are the vibrations??
Old Nov 20, 2011 | 08:47 AM
2k6ATL's Avatar
Probably a 3..and a 4 with the a.c. On
Old Nov 20, 2011 | 01:47 PM
bpalmeryat's Avatar
One other thing you may try is taking a look at the fasteners on the dynamic damper on the subframe, it's located on the rear crossmember. Check and make sure that they haven't loosened up.
Old Nov 20, 2011 | 03:37 PM
2k6ATL's Avatar
I have an 06 TL. Did they have the damper? I thought that was only on the 04 TL.
Old Nov 20, 2011 | 08:36 PM
bpalmeryat's Avatar
Yes the '06 model has a dynamic damper, but only for the AT, MT does not have it. If you need to know the torque spec, I can grab that for you at work tomorrow.
Old Nov 21, 2011 | 06:18 PM
hrod26's Avatar
Just throwing it out there but I had vibration at idle with the A/C on....after replacing motor mounts I figured out it was a bad ignition coil. The vibration was more in the engine (missing) than the steering wheel. (There are a couple threads on this if you search)
I would take front strut brace off and do a good visual inspection. These are hydraulic (oil filled) mounts and to my knowledge a failure should show leakage.
Old Nov 22, 2011 | 05:11 AM
2k6ATL's Avatar
Did it throw a CEL when your coil went bad??
Feb 25, 2020 09:57 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
