Auto trans problem
Old Mar 17, 2016 | 03:25 PM
bassix67's Avatar
6th Gear
Auto trans problem
Hello, I put a used trans in my 05 TL because mine died. Got the trans from a yard and it's warrenty is 90 days.
Now my car is really slow to go in 1st and won't go into 2nd or third. I swapped the sensors from my original tranny to the used one but did not use the original torque converter.
It also grinds a bit and bangs into park. And yes I know it's used but I didn't have the money for a rebuilt or have mine rebuilt.
Is there something I'm missing?
Old Mar 17, 2016 | 07:02 PM
JasonK's Avatar
09 TL SH AWD /w TECH
Yeah. Your "new" used one is fucked. Never just go pick up a 04-08 tranny from a yard. Chances are it's fucked. You either get it rebuilt or get a new one.
Old Mar 17, 2016 | 07:29 PM
MarcDavidoff's Avatar
Yeah sounds like that one is no good either. Should've done an accord trans AV6 swap
Old Mar 17, 2016 | 09:49 PM
csmeance's Avatar
Make sure the guide pins were installed properly when you installed the trans!
Did you try the trans with both sensors or just the ones you put in from the old trans?
Did you plug all the harnesses into the right places? Is your D light blinking or the Check Engine Light on? If yes, you'll need to pull the codes to see what is the cause of the electrical issue.
Best bet is to return it and get a accord v6 trans. You'll need to swap over only the range switch from your TL. 07 & 08 TL trans will not fit 04-06 tl.
If you did the install yourself, did you use the factory service manual to help direct you on how to do it properly?
Old Mar 18, 2016 | 11:25 AM
flyromeo3's Avatar
and use the TL flex plate if going the AV6 route.
Old Mar 18, 2016 | 01:55 PM
bassix67's Avatar
6th Gear
Yeah I wish I had the $$$$ to get a new or re-built.
Old Mar 18, 2016 | 01:56 PM
bassix67's Avatar
6th Gear
I tried to find a Accord tranny but was pressed for time. Not I can throw time out the window.
Old Mar 18, 2016 | 01:59 PM
bassix67's Avatar
6th Gear
I did the install with another mechanic. We followed the manny.
I'll go back and recheck.
Old Mar 18, 2016 | 07:07 PM
Scottwax's Avatar
Mr. Detail
I ran into the same thing with my first Accord, first automatic my mechanic found wasn't any good, 2nd one was rock solid. He went through someone else the 2nd time since he felt the first place was less than honest about the mileage it had on it.
And don't get me started on the rebuild I paid almost $2000 for initially...that was a year long horror story that included nearly 40 days of car rental while mine was back in the shop several times.
Old Mar 21, 2016 | 06:26 PM
bassix67's Avatar
6th Gear
ive done 3x3 trans fluid exchange and 1st gear is slow to engage and it only goes to 2nd.
i have a 90 day warranty. Might pull it and exchange for a v6 accord trans.
Old Feb 27, 2023 | 03:33 AM
Tonyhenryrivas's Avatar
3rd Gear
Oop
Looks like i posted in the wrong thread
666wokker
Apr 15, 2026 03:06 PM
Evilocity
Apr 22, 2016 09:33 AM
thebman
Mar 9, 2016 05:48 PM
tiger2471
4G TL Problems & Fixes
Mar 1, 2016 08:39 PM
rmcguire38
Jan 28, 2016 10:19 PM
