Any other 6MT'ers with clutch pedal click?
My dog thinks I'm Elvis!
1 Post
If I don't have the audio system on, I've noticed that every time I push in the clutch pedal that there is a slight audible click. Anybody else have this sound? I can live with it...it's really the only flaw I've found in my otherwise perfect TL.
Yea I discussed this before, and you can feel the click on your foot as well. WD-40 takes it right away. Spray it up under your dash where the ball bearing joints are which connect the pedal to the clutch hydralic.
1 Post
Yep - I have the same problem. The Service 'Mgr' for my area brought over some parts that he thinks will correct my problem - I just haven't had time to go drop off my car at the shop. I am now starting to notice once in a while my clutch does not feel 'smooth' when shifting - feels like the gears are slightly grinding. I don't know if one has to do with the other - but I hope it does not continue.
'04 6mt Pearl
Manufacturers need to start working away from mechanical switches and move to non-contact optical. We would benefit from a quieter cabin and a couple less complaints if they had thought this one through a bit more thoroughly. We've had complaints about both the brake switch as well as the clutch switch plungers which are both noisy, especially if pressed off axis. I am certain in time optical switches will replace the mechanical switches as costs of the mechanical parts goes up, and the opticals switch costs go down.
I guess this one rates pretty low on the cost benefit scale but they could have eliminated all these complaints with a few dollars worth of components.
Is it even worth the hassle to talk to a dealer about this problem? I do not want to sound or look stupid when I request a fix for this and they say that nothing is wrong with it
never stops!
SSM 6MT
I had this problem too when my car was a little over one year old. For my one year service, I mentioned and they fixed it although I'm not sure what they did. I think they just lubed it. The problem did not come back to date but we'll see if it does another year from now.
04 Anthracite,6spd,No Nav
yep, yep, I got the click too. particularily loud, and I feel it in my foot. I called Acura dealers on this, and they keep insisting that its normal and just something engaging. But I highly doubt thats it, because it feels like its coming from the pedal and not from inside the car.
If I press the clutch down fast, I don't hear/feel it as much, but if I press it down slowly, I feel/hear it everytime.
very hard to describe, but speedracer's analogy is pretty much how it feels.
never stops!
Originally Posted by speedracerIII
I have been having this similiar prob off and on....To describe how it feels....I would say it is like pulling a frayed cable thru a sleeve
Could not have described it better. Exact sound.
I picked up my car from the service and Acura also fixed my clutch problem. They replaced the clutch master cylinder and everything is much smoother without any hesitation in the pedal and noise. BTW my problem was exactly like Nello1’s – I could feel the click more often then actually hear it. Anyway the problem is solved, so I would advice people with a clutch problem to visit an Acura dealer and request the clutch master cylinder to be replaced
Howdy,
I took my 05TL into the dealer today for the sticky/clicky clutch problem. At first, they could not replicate my problem. So I went and picked-up the car tonight, and BANG it started doing it again.
The tech took a look, and found it to be the master clutch cylinder. They took my car back into the shop...I get it back on Friday.
It's strange the problem was not there in the morning, when the car was cold. Only after baking a day in the sun was the problem revealed.
Hope this helps other people with the problem!
For those in the Bay Area looking to get this problem fixed, I took my car into Pleasanton Acura. PM me if you want the tech's ID or my invoice # to help solve your problem.
Mm
Mm
never stops!
Originally Posted by mmorgensen
Howdy,
Mm
Mm
Forced Induction
Seems like I am developing this problem, I have 13k miles on my 2004 TL, and it just started clicking, and I can feel it everytime, it click when its almost at the end.
I really rather avoid taking the car in for service, so I will try to see if I can lube everything I see down there, and hoping it will solve the problem.
Shifting is the same, clutch pedal feel is the same.
Forced Induction
Originally Posted by subinf
Been going on for a few months now and I am a lazy ass and havent lubed the pedal yet.
Lubing it up will not do much good...The spring inside the master cylinder is defective and basically rubs inside the sleeve. Mine became more pronounced if the car was warm or if you let the car sit and idle...i.e....rush hour traffic. Acura replaced the master cylinder and all is good. There is a TSB on the RSX for the same exact thing...I used this to get negotiate what I needed.
7th Gear
Must be different causes. Master cylinder vs other. This has been driving me crazy and right before I was going to go through the dealer process I tried the WD40 and for 4 days now it is as smooth as it was when I got it. So much better.
We'll see if it lasts.... I already had it lubed recently at my last service visit which lasted all of a day or two.
I guess I'd recommend trying the WD40 first since it is so easy to do and if that doesn't work getting the dealer to replace the master cylinder.
Master Cylinder
ITs like speedracerIII said, replace the master cylinder and you should be good to go. I had the same problem and that is exactly how they fixed it. Good luck.
never stops!
Forced Induction
The thing is, trying to convince some of these asshole Acura service dept. to replace something. They are content on trying to prove its supposed to be that way.
I feel like everytime the car is in for repair, there is a greater chance of it coming back needing more work.........
I would recommend lethium grease instead of anything else........last a long ass time, might be a bit messy......I havent tried it yet, my problem seems to have vanished......for now
never stops!
Deadlock, ask them to go thru the TSX TSBs. There is one with this problem and says you've to replace master cylinder. That is what I did with my service technician and he agreed. I do not have the TSB no. handy though.
Need More HP!!!
I have a 2004 6MT and had this clicking when depressing the clutch in and then I stepped off the clutch. I brought it to the dealer back in 2004 and they mentioned a technical service bulletin about this. They replaced something (spring?) and it has not come back since.
If it is in the clutch pedal assembly you hear the clicking, tell your dealer to check back on 2004 TSB's for this issue. Mine was resolved under warranty and has not come back. Good Luck!
My 2004 6MT had the clicking sound and a binding/pop feedback you could feel in the pedal. Seemed to be worse when it was warmer (> 40 deg F). Dealer replaced the master cylinder under warranty. I think the Accord Coupe 6spd had a TSB on this as well. At the time I wasn't able to find a TSB for the TL.
I got the clicking sound too. i took my 6MT into the dealer twice and they could not fix it. saying i was the first and only person to complain about the issue. so the tech went ahead and ordered a new clutch assembly for me. will be getting it fixed soon.
i really think we all should get together and write a formal complaint to corporate headquarters. and maybe they'll get a bulletine out.
2004 6MT.. i got the pedal click.. when the radio is on im not bothered by it... but sometimes i like to turn it down and thats when it bothers me. not only can i hear the slight click ( i hear a couple ), but i can feel it as well. can the rest of you feel when it clicks?
Forced Induction
yea I can deff feel it..........very very annoying, but it hasnt come back yet, I am covered till 62k miles (only have 13k miles on the car) so I am not worried, I will get it replaced soon.
after two attempts at fixing the problem, i told to dealer to just replace the clutch assembly itself. this solved the clicking problem, and i don't know exactly what it is but my car feels more powerful and shifts alot smoother. it was all covered under warrenty so i didn't have to pay out of pocket. you guys should consider replaceing the clutch assembly.
Originally Posted by jmichaelp
I have the squeek, but not sure about the click. Is this the same master cylinder problem?
