ALL Lights flashed like crazy - No power
Hey guys,
My sister went out with my TL and just called me and said while she was driving all the lights off the car turned off, but the engine still ran.
Then she stopped at a gas station; filled up, then tried to start the car and all the lights went crazy flashing (interior lights and exterior lights, reverse lights, etc) and then no power. Car didn't even crank.
Told her to pop open the hood and make sure all my connections for the accord fogs are good, and then she played around with them a little and then she tried to start the car and it worked.
Now everything is working fine, but do you guys know what the problem is?
Is it something with my Accord fog connections? Just yesterday I wired them up using butt connectors.
The Accord fog wiring is right by the negative terminal, so could it be possible a wire touched the terminal and made my car go nuts?
I'm scared as hell right now, and will check it out when she gets home tonight.
Thanks!
Thanks!
If the only thing you've changed is the fogs, then run all the wiring to see if anything came loose and/or might be shorting something. Make sure all the wires are properly protected, also.
Maybe the exposed part of the wire touched another wire or the negative terminal?
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
HeloDown
09-08-2015 06:51 PM
