Adjusting Air Bypass Valve
Old Feb 28, 2020 | 10:13 PM
motobrad14's Avatar
5th Gear
Hey guys,
on a trip
just did a timing belt and put 300 miles on the car.
having problems with power. Car is low on power and always feels like it’s in the wrong gear.
I did remove the Air Bypass Valve near the power steering pump during the timing belt removal. I did not know it had gears and lost the timing of the motor.
I brought tools with me to readjust it, but does anyone know which way the gear on the intake manifold will go for full open or full closed? I do not think the valve is opening fully on the highway.
please help. I did search google and this forum and cannot find any links on adjusting or installing this Air Bypass Valve.
thanks
Old Mar 2, 2020 | 11:20 AM
Catzilla's Avatar
Bump for same problem, in the middle of valve cover gaskets and did the same thing.
Old Mar 2, 2020 | 12:45 PM
motobrad14's Avatar
5th Gear
All data response
I’m working with all data for a solution. I’ll post it when I find it
Old Mar 2, 2020 | 05:04 PM
motobrad14's Avatar
5th Gear
https://acurazine.com/forums/2g-cl-f...dd-faq-424532/
Old Mar 3, 2020 | 04:33 AM
Catzilla's Avatar
Aha - knowing to search for keyword IMRC has yielded more fruit!
https://acurazine.com/forums/third-g...nstall-932779/
Old Mar 4, 2020 | 10:30 AM
Catzilla's Avatar
Update: success!
With car off, bypass doors are closed and actuator is at rest. The actuator unit has a tiny clocking key that fits into a notch on the cover, and the acutator's gear teeth slide right into the bypass door's gear and two hex bolts tighten smoothly. Sorry for no pics, had greasy hands.
Test drive had great power, no lag or off-key behavior. Felt better than ever!
rajivdiwan
Oct 24, 2017 07:27 PM
mklaudt
Mar 19, 2009 04:24 PM
danny_isr
Nov 26, 2007 09:01 PM
LiQiCE
Feb 9, 2006 10:43 AM
dom
Sep 21, 2005 08:50 AM
