Acura TL W/ ECU swap CEL P0627 Emmisions
I bought a 2008 Acura TL that has been engine-swapped with a J35 Type S engine along with the ECU, I am getting a CEL "Fuel Pump A Control Circuit/Open P0627" which won't allow me to pass emissions. I've already taken my emissions test knowing I would fail to buy more time. I want to know if the car is throwing this code because of the engine swap/ECU and if it is can I get a Ktuner/Hondata flashpro to switch off the code to pass emissions or is there something wrong mechanically?
Welcome to the forums. The forum where you originally posted, the AcuraZine User Help, Support & Suggestions Area , is meant for problems, comments, and suggestions for the website itself. so I moved your thread to the car specific forum applicable to your vehicle.
This was explained in the sticky thread at the top of that forum, or click here if you can't find it, which will explain why you shouldn't have posted your thread there.
https://acurazine.com/forums/3g-tl-p...rcuits-995792/
