Acura 2004 TL
Acura 2004 TL
i just bought 2004 Acura Tl with 196371 miles on it and i don't know that much about acura if any one could please tell me what is the best thing to do the car at first so it will not give me a lot of problem. what part should i worry about most should i put most work in engine ? or just tune it and change filter chip intake etc ?
would using seafoam to clean the engine good idea?
thank you
thank you
What did the mechanic say that inspected it before you purchased it? fluid and filters are always a good call. has the timing belt /water pump been replaced? transmission serviced? Absolutely no reason to run seafoam unless maybe its never had an oil change or always was fed 89 octane fuel. There is no chip..............and the stock intake is perfectly fine.
timing belt/water pump/spark plugs
transmission. (if automatic)
AndrewS
19
03-14-2024 06:59 PM
jamestheunderdog
07-19-2016 07:58 PM
sockr1
10-01-2015 01:31 AM
Gianni Formica
09-07-2015 08:28 PM
