AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   3G TL Problems & Fixes (https://acurazine.com/forums/3g-tl-problems-fixes-114/)
-   -   AC Question (https://acurazine.com/forums/3g-tl-problems-fixes-114/ac-question-1000084/)
cinobyte Jul 30, 2022 11:25 PM
AC Question
I recently had an electrical burning smell while driving it came and went pretty fast and I didn't notice mechanical problems but when I got home I noticed the ac compressor wasn't engaging. I checked all of the fuses and they looked good. I thought I remembered reading something a long time ago about something under the dash maybe on the passenger side that would burn out and cause the AC to stop working but couldn't find it.
if I turn on the ac the engine will idle down for a second like it's trying to engage the system but the compressor never engages.
does anyone have any ideas or is it just time to replace the compressor?
TIA
peter6 Jul 31, 2022 08:48 AM
Check if compressor clutch gets power. It it does and don't engage, you need coil and or new clutch, or whole new compressor.
You can visually check if clutch is engaged, as middle portion of the A/C compressor's pulley will either be stationary or spin together with outer part.
cinobyte Jul 31, 2022 07:19 PM
I noticed it wasn't engaging as soon as I got home that day. and it hasn't engaged since. I will have to see if it gets power and go from there.
Thank you
© 2026 MH Sub I, LLC dba Internet Brands
