From 31 H-MPG to 36 H-MPG *Tire Pressure
I have noticed by upping my tires PSI to 40 it has helped gas milage significantly .
When I was running 32PSI I was averaging 31 MPG Highway. Past two months Ive been running 40PSI and I have been averaging 36 MPG Highway 22 mile commute each day to work and back. (44 miles total daily) |
Keep an eye on uneven tire wear .
Originally Posted by louisville88
(Post 12354335)
I would watch for 2 things: premature wear in the center of the tire (the tire is not "sitting" on the road with its full width)
On tire could actually explode - you're running 40 psi - that could weaken the steel belts - speaking with logic on this, I don't know for sure, haven't heard cases or had experience with it |
Originally Posted by Bogdan TL
(Post 12355123)
On tire could actually explode - you're running 40 psi - that could weaken the steel belts - speaking with logic on this, I don't know for sure, haven't heard cases or had experience with it Acura actually recommends 39 psi for the front tires on any TL using the 18" A-Spec rims, and the owner's manual also recommends 39F/36R on the 17" wheels for sustained high-speed (118 mph+) driving. Tire construction during the past 20 years also allows for regular street operation at 40 psi. I wouldn't run beyond 40 psi for regular operation (as opposed to track or autocross) though, partly because I grew up in an era where bias-ply non-radial tires were more common than radials. However, a higher rear tire pressure (with less pressure differential between front and rear) may permit a little more understeer/plow when driving closer to the edge. It's a good idea to keep an eye out for uneven wear while running 40 psi. I always run 36-37 psi up front and have yet to encounter uneven wear, from either the OEM MXM4s or the replacement S4s. |
I run 38psi in the front and have been getting 33-34 mpg on long trips (260miles) at 70mph. I dont really perform and hypermiling techniques, But I will try stay a very safe distance behind trucks/cars going 70mph if possible. I also coast alot if I see braking will be necessary, and I wont accelerate hard. When getting an alignment recently they commented on my tire pressure saying that it would cause uneven wear, but ive driven a ton of miles like this, no problem.
must be nice to get those type of numbers, i guess i drive to fast, 24mpg is good for me
Maybe thats why my mileage dropped since I bought the car. Bought it was getting no worse then 19mpg and then as the temp cooled I have been getting 17mpg and I noticed the tire pressure has been 32psi versus the 38-40 it had when I bought it.
Originally Posted by Turbonut
(Post 12354814)
Sorry, but increased tire pressure will not yield that type of results.
<- also from louisville |
Originally Posted by cmluckett
(Post 12889628)
That being said, I don't think it's unreasonable that louisville88 is getting that kind of mileage. I would, however, warn him that 40 F&R is too high and very dangerous as I ran 38 F&R for a minute and was hydroplaning everywhere (orig EL42's). That was a little too scary for me (albeit I run between 80 - 90mph to and from).
(Post 12890011)
40 psi is no problem as many tires have a 50+ psi max rating
(Post 12890011)
you won't see a 5 mpg increase by increasing the psi 8 lbs.
http://farm3.static.flickr.com/2235/...e5e5043796.jpg Running 36psi cold front & rear. Maybe mine is just more aerodynamic. :boink: |
could partially be caused by a switch from 'winter blend' gas to 'summer blends'? any thoughts
can't rule it that out. good call. ymmv.
(Post 12945398)
EL42's max at 40psi (just fyi):
(Post 12945398)
MID don't lie (well, that's not exactly true).
dude probably changed his driving habits either on purpose or inadvertently.
I can get 36 mpg doing 60 mph on tires at normal pressure, for about 100 mi |
:werd:
you will not see 5mpg go up when u pump 5more psi in your tires....couple things you wanna take care of: 1> Uneven Tire Wear 2> Most tires max psi is 43-46....40 cold psi mean you are pretty much pushing the limits.... 3> Maybe your driving style changed....i get 33mpg hwy all the time....got picture proof.... I ride at 35 cold psi....and get amazing mileage....i have upped it to 38-39 and got the same mpg.... do yourself and ur tire a favor....turn it down to 36 or lesser.... |
I do stand corrected. For my for my information [sic], EL's are indeed 44psi max cold.
".i get 33mpg hwy all the time...." yep, same here with exception of the sweltering summer heat/humidity which dropped me to 29mpg average over 9,600+ miles. |
45 miles is hardly a decent statistical sample. I can get >50 on a 10 mi long down hill stretch it is going up the otherside that kills my mileage.
(Post 12890011)
40 psi is no problem as many tires have a 50+ psi max rating, however, you won't see a 5 mpg increase by increasing the psi 8 lbs. If it were that easy, the manufacturer's wouldn't be scrambling with lighter cars, more fuel efficient engines, they would just construct a vehicle with soft suspension and put 45 lbs in the tires and then you'd have a V-6 that gets 40 mpg highway.
