207-2008 TL transmission pops out of gear HELP!!!
What’s going on everyone so I’m having this issue with my 07 Acura TL Auto 5speed just replaced the ATF DW-1 and all 3 pressure switches and when coming to a stop at a light and try to accelerate again it jumps out of gear and revs as it if it’s in neutral all other gears shift in good no slipping car has 105k miles no leaks and also no metal shavings when I drained the old fluid before replacing the fluid it was shifting rough but not the slipping out of gear now it shifts a lot smoother but slipping out of gear when coming to a stop any one had this and has a fix thanks in advance.
Any engine light? Codes? Did you use OEM sensors?
Yes oem switches the reason I replaced switches was because It was already doing in and
no lights on the dash so I replaced the fluid 3x then started doing it and that’s why I replaced the switches
and still has the same issue
how much fluid did you put in?
did you compare that amount to how much you drained out? you may have overfilled/underfilled as well.
https://acurazine.com/forums/3g-tl-p...sensor-730958/
do you see symptoms like this , could be your app sensor
07-08 3TL transmission pops out of gear HELP!!!
Another post see if I can get help
have a 07 Acura TL just got the 3x3 trans fluid replaced and all pressure switches after replacing the fluid when coming to a stop and accelerating again it revs up like if it’s in neutral and then goes into gear again by itself it does it sometimes only not all the time anyone help me out or had this issue car has 100k miles no leaks all other gears shift good
Latent car nut
As a suggestion, if I am not mistaken, this is the third thread you've created on the subject of your transmission issues; in the future it might make sense to use just a single thread for all of your posts.
no it’s the second one and I’m doing it because I’m the first one I had no help or anyone with the issue that could help me out
I'll just keep merging them
Motorista
4G TL Problems & Fixes
78
10-13-2010 11:55 AM
01-25-2010 06:26 PM
EscaBoi
1G TSX Problems & Fixes
05-12-2008 10:20 AM
