2007 TL Type S oil leak
so my car seemed fine no oil leaks before. brought it into the garage to do some cleaning on the inside and left the car running while i did so. when i backed out of the garage there was what looks like oil from under the passenger side front of the car. the oil on the ground is goldfish yellow but my oil is a little darker so I'm not sure what this would be. if anyone knows please let me know
i dont even think there is a goldfish yellow colored fluid...
Brand new oil is Honey colored. but you say, you've been running your oil for a while, and its not a yellow color any more.
hmmm, put a piece of card board underneath the car over night to see if anything drips.
but, with your description of gold fish yellow colored fluid, I dont think it came from your car.
The A/C drain tube drains condensation near the front passenger tire.
The condensation is straight water.
You may want to feel the fluid that fell under your car to see if it's water, as opposed to a viscous/oily fluid like PS fluid, motor oil or transmission fluid.
If it's water, then it's probably just water from the A/C system.
Welcome to AZ.
Welcome to AZ.
Welcome to AZ.
Welcome to AZ.
the fluid on the ground could look different than water (even if it is water) if the ground is dirty.
so i was checking it out today and color and feel matches the ps fluid so I'm going with that. I'm taking it in next week for timing belt, water pump, oil change, atf fluid change and something else so ill have them check it out for me
IIRC, there was also a wiper motor recall.
MilanoRedDashR
38
Sep 28, 2019 09:13 AM
IIDXholic
Oct 8, 2015 07:53 AM
winkyyy
Sep 11, 2015 04:40 PM
at goldfish autocorrect
