at 3rd and 4th gear problem
Old 01-19-2010, 07:39 AM
nighthawk2004's Avatar
i have the same problem that everybody else seems to have, when it shifts to 3rd and 4th the car rattles and shakes, i changed the gear pressure sensors but that only helped a little and i also changed the transmission fluid 1x refill what else can i do to fix it, im planning on doing another refill next time i change my oil and then one more time to make it 3x
Old 01-19-2010, 07:41 AM
Fearless DIY Guy
DeathMetal's Avatar
There's a TSB for this, IIRC...use the search function, there's a huge thread about this.
Old 01-19-2010, 09:31 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
MT: GM FM Synchromesh MTF
AT: 3rd & 4th Gear Pressure Switches.. 3x3 & AT Filter change.
Old 01-19-2010, 09:34 AM
Bender's Avatar
Yes, I works like a charm. Make sure when you go to buy it that it says "Friction modified" on the bottle. Otherwise it isn't the right one. I got mine at a Cadillac dealer.
Old 01-19-2010, 10:46 AM
Jared234's Avatar
I Put in the AMSoil FM and its 100 times better than the factory stuff
Old 01-19-2010, 06:04 PM
Newb
spicynoodle116's Avatar
until its fixed, i suggest shifting in sports mode. i let go of the gas a little bit or completely when i up shift, and my car doesnt shake when changing gears.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
NitroViper
03-20-2017 09:50 PM
BadassAcuraCl
1G CL Problems & Fixes
09-14-2016 03:26 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
carz0159
09-20-2015 06:11 PM
Quick Reply: at 3rd and 4th gear problem
