Check engine light/D light blink code P0816/P0958
Old 05-06-2015, 07:10 AM
acufan1's Avatar
Having problems with my 2005. Check engine light came up and the codes are p0958 and p0816. I did the paperclip thing and the D light flashes give me the code #24. I was looking into this but I haven't found anything accurate enough to go ahead and buy the pieces needing to be replaced. Options range from replacing Part #: 35740-SEC-A82 (SWITCH ASSY., PARKING PIN & SHIF), SWITCH ASSY., sport shift solenoid, Downshift Switch Circuit, auto shift manual mode circuit high.
So any help on how to proceed will be greatly appreciated. Thanks!
Old 05-08-2015, 10:57 PM
acufan1's Avatar
Anybody?
Old 05-09-2015, 12:55 AM
csmeance's Avatar
Received 1,988 Likes on 1,412 Posts
straight from the 2004 tl service manual:
acufan1 (05-09-2015)
Old 06-12-2015, 08:19 PM
eusoj50's Avatar
Blinking D light
BY your left front wheel, you will seen the 3rd and 4th pressure switches. My D light was blinking too last month. I changed those switched with brand new ones from the acura dealership and that problem went away.
Old 12-04-2018, 04:13 PM
Hansell M Disla's Avatar
P0816 check engine light on and d blinking light any help
Hi i just wanted to ask you your car had the engine light and the d blinking light when you changed the 3rd and 4th gear pressure switch and it went off at the time you changed ?
Old 12-04-2018, 04:20 PM
Received 8,577 Likes on 6,627 Posts
that's what he said..
Old 12-04-2018, 05:54 PM
ok i got it now .
Old 12-13-2018, 07:32 PM
I have the p0816 d light blinking and the chech engine on
[QUOTE=csmeance;15432008]straight from the 2004 tl service manual:
Hi can anyone help me my car have the p0816 code stored the d light is blinking and the check engine is on. I try fews mechanic already one told me the dual pressure selenoid was bad i did changed and the same problem still and i went to other mechanic and he told me may be the 3rd and 4th gear pressure switch are bad i changed with original one and nothing happen still got the same problem now i take the car to another shop and the guy told me i have the neutral safety switch bad but i dont really think is that.. if someone had the same problems and know how to fix it please let me know i need help with it thank you..
Old 12-13-2018, 08:30 PM
If you read the service manual, it sounds like you need to replace your transmission gear selection switch.
Old 12-14-2018, 05:47 AM
did you know whats the part number for this part?
changt82
11-19-2019 03:36 PM
CmMx112
07-30-2019 08:44 PM
majin ssj eric
05-20-2019 08:20 AM
qliu8
11-17-2018 06:35 PM
GraveDigger
11-14-2018 09:20 AM
Quick Reply: Check engine light/D light blink code P0816/P0958
