2007 Acura TL Evap Purge Valve
So i had the fuel cap needs to be tighten warning message. I came to this site and found out it's the Evap Cannister Purge Valve. So i changed it and the warning message hasn't comeback, but now I have 4 different CELs to do with the evap purge valve. I thought I might have boughten a bad evap sensor because it did have bad reviews, so I bought a different one with good reviews, installed it and drove it around for 10 minutes and the CEL still won't go away. Anyone else have this problem?
Buy an OEM one..
I finally got around to replacing the purge solenoid. 10 minute job, easy to do.
Amazon $25 part, "appears" to be OEM.
Registered but harmless
Received 1,102 Likes
No CEL or message since the replacement about 300 miles or so ago.
Becareful as there are counterfeit parts float on the market and Ebay is pretty notorious for that.
MDXTL1206 (04-08-2018)
I just ordered my $25 "oem" purge valve and will complete the job on Sat. I saw another thread that described this same issue..."tighten fuel cap" message with NO DTCs or CEL which matches what my 06 TL is presenting. Had the service bulletin and everything. I'll be glad to have it done, and on the cheap. Thanks for your voice of experience!
I recently bought a '08 TL-S 6MT and had the tighten fuel cap message. I replaced the EVAP Purge Valve with an OEM part from Amazon and it fixed the problem.
After replacing the part, you have to drive a couple miles for the message to disappear.
This is the part I bought -
Latent car nut
Received 2,005 Likes
- Dried out and/or cracked rubber hoses in the EVAP system
- Rusted out gas tank
- Rusted out fuel lines
skierz (12-17-2018)
The video I attached is how to check if your purge valve is working properly. This one was from china (always get Japan parts) and wasn’t until I fixed it you can here the switch inside going on and off making a “clump sound”
watermarksham
03-08-2016 11:21 AM
bamaboy_56
01-10-2012 10:45 PM
