2007 Acura TL 100k miles...possible electrical problem
Hi guys, haven't posted in a while, but I noticed sometimes on my car in the morning I'll unlock it, get in to start and it won't start. No lights, nothing...wait two minutes and the start starts up like normal. I need to re-enter my radio code and Navi code. I checked the battery terminal, no corrosion, the terminal are tight, not loose.
Any ideas?
The car has not turned off on me (as of yet) while driving.
Also my engine temp is higher than normal, but below the middle temp part.
Any help is greatly appreciated!
Any ideas?
Check the grounds. Check the fuses. See if there's anything obvious that would be causing an intermittent connection.
For the engine temperature: check your coolant levels and maybe see about replacing your thermostat.
