2006 acura tl dash lights out
Old 11-18-2018, 07:23 PM
3rd Gear
Cobmister09's Avatar
2006 acura tl dash lights not working completly black, windows not working, wipers not working i have no clue what happend
Old 11-18-2018, 07:28 PM
Joecop67's Avatar
Part out.
Old 11-18-2018, 08:19 PM
Registered but harmless
Will Y.'s Avatar
Received 1,102 Likes on 763 Posts
Does everything else work- engine turns on, headlights and radio operate?
If yes, check fuses.
If no, check battery, clamps, battery cables and grounds.
G/L.
Old 11-18-2018, 10:14 PM
Pair of TLs's Avatar
Yup
G/L.
Start with the battery..could be a loose connection for all we know.
Old 11-21-2018, 10:14 PM
3rd Gear
The engine does turn on its just the stuff that i said was wrong just that
Old 11-22-2018, 10:06 PM
Question Now what?
Did you check the fuses?
Old 11-23-2018, 05:40 AM
3rd Gear
Yes i checked the fuses that the first thing i did
Old 11-24-2018, 01:14 AM
Will Y.'s Avatar
The problem still sounds like a fuse or relay.
Try pulling and replacing the #7 fuse in the under-dash fuse box, then fuse #4 in the engine-bay fuse box.
(Confirm those fuse location numbers with the diagram on the fuse box covers and owner's manual)
Don't look at the fuses- just pull and replace with a new one.
Or use a multi-meter to determine if there is a problem with those fuses or one of the MICU fuses.
Old 09-30-2020, 08:51 PM
mnorto3's Avatar
So - Did this work?!
fuslove
1G CL Problems & Fixes
02-19-2021 12:39 AM
Acura818z
05-21-2013 03:43 PM
kenny84
1G TL (1996-1998)
06-15-2007 04:54 AM
Thomwarn
07-20-2004 07:49 PM
Quick Reply: 2006 acura tl dash lights out
