2005 Acura TL steering problem (whinning)
I did multiple research about the whinning sound in my 2005 acura tl. All research said to replace the two gaskets. I did that but the noise is still there on a cold start up. The noise does go away when the car warms up. I been doing research but idk whats next. I dont want t jump in and change the pump and it might not be that. Please help. Thanks. Bumps appreciated.
Tried that already. Did it back and forth even while raising the rpms. and i tried to get out majority of the fluid and refilled. Same things going on. Can it be another o ring somewhere else or a gasket? Thanks.
Air can only enter where external air pressure exceeds internal pressure. This is on the suction side near the inlet or pump body.
I had this problem on MDX and found that a HP hose leak was allowing PS fluid level to get low enough to pull air in at the reservoir.
good luck
good luck
Registered but harmless
Received 1,149 Likes
Call the dealer to check to see if your '05 TL had the recall work done. If not, have the dealership do the recall work before doing anything with the pump.
mike from annapolis
05-07-2017 08:21 PM
handsom-hustla
11-13-2015 05:04 PM
nuldabz
09-03-2015 05:49 PM
