2005 Acura TL starting by itself with no key?
so out of the blue i go to start the car this morning and it turns over like the batteries dead. ok no problem. take the key out of the ignition and it tries starting itself. then a couple seconds later it tries starting itself again. put the key back in and it stopped. i dont know if it was from the key but it stopped then. battery has some fluid on it so i assume its a wierd glitch due to battery failure. put my yellowtop in and as soon as i connect the cables it starts itself! shuts off then starts its self again. shuts off and starts itself again! i had my wife put the key in the ignition and it stops after the third time starting. is this a normal sequence the car goes through or do i have something wrong? it shouldnt even be able to start without the key should it?
HEAVY_RL (02-11-2012)
I had the same problem on my car so i took it o the mechanic and it was a alarm sistem that was doing a short and of course it damage the starter so this guy took all the wiring from the aftermarket alarm out unther the steering weel and replace the start so all its fine now did you car have an aftermarket alarm ? could be that i thought that was the ingnition switch too but this came out hope you find the problem
i did get the car used. it has the stock alarm i believe. it does have a back up camera though. it hasnt done it in the past couple days. only when the battery gets low or it just regains power. cant tell with the remote start unless i really dig into it.
tman570
06-11-2019 08:56 AM
Legend2TL
11-20-2015 08:31 PM
handsom-hustla
11-13-2015 06:04 PM
nuldabz
09-03-2015 06:49 PM
