2004 Acura TL Check engine light flashing and rough running
Suddenly happened while driving to work a few days ago, check engine light came on and engine started sputtering/running bad. I'm able to drive it no problem but it seems to be a misfire from what I've read online? I changed the plugs and still the problem persists ... error codes reading are P0174, P2197, P0302, P0303, P0305, P0300, P0301, P0304, P0306. :/
bad coil
Any reason it wouldn't give me a coil code ?
either coil your it could be your 02 sensor goes bad.
