2004 acura tl 6 speed
My 2004 tl has a slight oil leak problem. Looks like its coming from the back of the engine but im not sure from where exactly. it is engine oil for sure... Has anyone had this problem? Can anyone help?
maybe it's the valve cover gasket. i'd buy an extendable mirror from autozone and a flashlight to see. the only unsealed part where oil could leak from on the top of an engine is the valve cover gasket. go under the car and see if you can identify it from there also.
practicing nihilist
you can pull the Intake Manifold off pretty easy to get a better look back there. Just watch the tork on the bolts when re-installing it. good luck...chasing oil leaks on the back of an engine can suck
AndrewS
19
03-14-2024 06:59 PM
handsom-hustla
11-13-2015 05:04 PM
