'07 TL Type-S bad MPG
K so I got a 2007 tl type-s around 31,000 miles changed the air filter bought a OEM one from Acura installed it, changed the oil/oil filter once every 3,000 miles and from time to time I get a TIGHTEN FUEL CAP message. My gas mileage is around 14 in the city pretty bad right now I think my car is running to rich due to something. Tire pressure is always at 34/36 psi. Im consdering replacing the EVAP Purge Valve which what seems to go bad in the tl-s but Im not sure. Also not sure if i should replace the plugs since the car only has 30,000 or can it be a bad fuel cap????
Wouldn't hurt to check the plugs, but they are supposed to be good for 100,000 miles. I changed mine at 65k though just because 100,000 miles seems like a long time for plugs to be in there. Mileage is a tricky thing to use as a diagnostic tool or as a symptom of a problem. How does the car run? Any changes in performance or sound/feel?
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
