'07 TL-S Rear Swaybar Link stripped & A-SPEC questions.
Ryan's loving his ATLP TL
I just installed my A-Spec yesterday and I was curious if anyone knows the part # for the Type S-6MT A-Spec Suspension. I want to match them to see if they're correct. Also I ended up stripping and having to cut off the end rear stabilizer links. What would you recommend I buy to replace the rear end links? I want to keep my tires as long as I can, I remember last time I did an A-Spec suspension I went through tires FAST, especially on the rear. I'll be driving the car about a week I take it until I receive a part. So I'd like some suggestions and if anyone has that part #. Thanks everyone!
AZ Community Team
Received 7,771 Likes
1 Thread per topic please.
Closed: https://acurazine.com/forums/3g-tl-2004-2008-93/part-07-tl-type-s-6mt-spec-suspension-866328/
Either OEM, Moog, or FastLine(?) End-Links. IIRC, HeelToe or Excelerate recently posted a comparison of the Moog and FastLine(?) end-links.
Closed: https://acurazine.com/forums/showthread.php?t=866328
Also would Autozone have the OEM links?
I just called Advanced Auto Parts and they said they have a left and right rear Moog stabilizer link. So I'll go and pick those up very soon! As for the part # That still worries me. I installed the A-Spec suspension so I just hope it's the correct one. I ordered the specific manual type S version. Just want to clarify that part #. I'll try to get the front real soon!
AZ Community Team
No, local parts stores will have or get Moog. The OEM is available at the dealer.
You can look up the Moog part number here: http://www.fme-cat.com/PassengerCarLightTruck.aspx
OEM here: http://www.acuraautomotiveparts.org/...ry3=&catcgry4= Put you car data in, then check the Front Lower Arm and Rear Lower Arm sub-assemblies.
The question thats still been bothering me is what is the correct part # for the Type S 6MT A-Spec Suspension? The reason I ask is, it looks almost stock height, I thought I noticed a more dramatic drop with my base TL than my Type S. It feels a little firmer than the Type S Suspension but not dramatic, though around turns it did show in better cornering.
justnspace (08-20-2012)
AZ Community Team
There is no A-Spec suspension listed for the Type-S. Only for the Base models.
http://www.acuraautomotiveparts.org/...mp=Accessories
Maybe PM the OEM vendor, Tim at (?) Hondacura World. I think his screen-name is OEMPartsGuy (something like that).
My Acura TL Type S 6-MT suspension kit part number is: 08W60-SEP-201B. That part number supersedes other part numbers that are floating around on the web - I called Curry Acura to confirm before the kit was installed.
Answer your questions?.
its not the aspec suspension thats causing your tire wear, its your alignment. it goes off anytime you mess with suspension parts. and its definitely not your rear sway bar link thats causing your tire wear
nuldabz
09-03-2015 05:49 PM
